86 F250 Diesel Transmission Problems - Ford Truck Enthusiasts Forums
Old 03-08-2013, 05:58 PM
1986F250Diesel 1986F250Diesel is offline
1986F250Diesel is starting off with a positive reputation.
hi. i have a 1986 Ford F-250 6.9L Diesel. great truck. ive had it little over two weeks and the transmission went out. i dont much like the 3 spd. im wondering if an aod would bolt right up to my engine or if i will have to do alot of modifications. should i just stick with the three spd and rebuild it or would it be possible to get an aod?
Old 03-08-2013, 06:57 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
You could do an E4OD with an aftermarket trans controller. I don't think they ever put an AOD behind an IDI...
Old 03-08-2013, 09:31 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Heck they never put an AOD behind a 351 from the factory. Tranny is to weak in stock form to take the torque.
Besides, not the same bell housing bolt patern. Your only choices for autos behind these diesels is the C6 witch you currectly have, and the E4OD.
Old 03-08-2013, 10:46 PM
airdale94's Avatar
airdale94 airdale94 is offline
airdale94 is starting off with a positive reputation.
Won't the 4R100 bolt up to it?
Old 03-08-2013, 10:52 PM
It sure will!
Old 03-08-2013, 11:01 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
the 4r100 is the E40D upgraded and renamed.sadly with flaws of it's own introduced though.
(a few easy changes and they can work behind the idi with oem controllers.)
Old 03-09-2013, 12:40 AM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Best options are a T19 or ZF5....
Old 03-10-2013, 08:42 AM
charger6t9r charger6t9r is offline
charger6t9r is starting off with a positive reputation.
If I could find a zf 5 4x4,I have a flawless e4od behind my 7.3 rite now I will be selling.58,000 on a rebuild.
Old 03-10-2013, 02:57 PM
Red454sedgwick Red454sedgwick is offline
Red454sedgwick is starting off with a positive reputation.
no overdrive is simply going bolt up behind your 6.9.
I had the three speed auto and hated that thing, I put an e4od in it.
it took the after market controler
diffrent drive lines
I had to make my own crossmember
I was lucky that my speedomer cable streached to fit.
Old 03-10-2013, 07:52 PM
NAVYVET's Avatar
NAVYVET NAVYVET is offline
NAVYVET is starting off with a positive reputation.
Howdy Y'all,
I have the same question about upgrading my C6 to an AOD to increase my fuel mileage and drop my rpms. Tell me if I'm wrong, but from what I gather from y'all the E4OD is the best way to go as the replacement for the C6. I have a 1986 Ford F250 with the 6.9L Diesel and C6, and a Banks Sidewinder Turbo System from the engine to the tailpipe. What all am I going to have to do to make the switch correctly??? The truck only has 155,000 Original Miles on it, so would you go with a NEW Jasper E4OD or just find a fairly low mileage used one??
Old 03-10-2013, 08:49 PM
I'd go find a Rebuilt E4OD. A stock E4OD won't last very long, heck some didn't even make 100k before needing rebuilt.
You'll just need the tranny, and cross member, and a stand alone computer for it, and your set! I think you'll have to shorten your driveshaft as well, as I remember reading the E4OD is a big heavy long transmission compared to the little C6.
Old 03-10-2013, 09:20 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Quote:
Originally Posted by NAVYVET View Post
Howdy Y'all,
Yes, the E4OD is the best way to go if you want an AT. If you want a 5spd MT, the zf5 is the best way to go.
Old 03-10-2013, 09:24 PM
NAVYVET's Avatar
When you say "stand alone computer", what year range will I need to get this from?? Also, will this swap run me about the same as going with the Gear Vendors setup, roughly $3,000.00???
Old 03-10-2013, 09:27 PM
You have to order a stand alone computer. Never came on these trucks.
And yes roughly the same. But as a bonus to the E4OD over the C6/GV is the E4OD has a locking torque converter while the C6 doesn't...... personally I'd go with a C6/GV but that's my old fashion ***
bashby's Avatar
With the gearvendors and a c6 you still don't have a lockup converter.
AOD behind 6.9 Diesel? youngone22 1987 - 1996 F150 & Larger F-Series Trucks 4 08-13-2012 12:15 PM
1986 F-150 transmission swap? Blackandchrome1986 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-11-2010 10:49 AM
7.3L Diesel to 460 Gas swap 1979F1504X4 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 05-23-2008 11:55 PM
Zf 5 spd bellhousing pattern Jason6969 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 07-04-2007 11:44 PM
Swapping out 351W for 6.9L IDI Diesel WA1986F-250 Engine Swaps 9 04-17-2007 07:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
