Fuel tank suction tube
I just ordered a new fuel tank for my 93 and I know that the pick up tube is going to be in bad shape. What is the best thing to replace it with? Will standard 3/8 fuel line hold up being submerged in diesel? Should I have some sort of strainer on the end of it? Does it need to be weighted to keep it on the bottom of the tank? I know several people have made their own any pictures out there of what you have made that worked good would be helpful.
I used regular fuel hose. Technically this is wrong as it's not designed to be submerged.
You can get the proper hose online or you can order it at Napa, but be sure to specify submersible fuel hose. Very pricy $$$
I cheated because I plan to revisit pulling my bed and removing the sending units to repair or replace the circuit boards to get my gauges more accurate. At that time I'll inspect the fuel hose for damage or swelling and determine then if I need to get the right stuff.
I only V notched mine, no strainer, but you're right, there are a lot of different ideas done by the different members here.
