2006 F-150 wont run
Old 03-08-2013, 04:04 PM
TANGO420's Avatar
TANGO420
TANGO420 is offline
2006 F-150 wont run
I have an 06' F-150. Last monday went to start and wouldnt crank over. I have since replaced FPDM, a weak fuel pump, checked Fuel Inertia Switch and now that they are all replaced when I check codes it says "no data available". Pump will not come on. Fuses have been checked. I have traced this problem to everything I can think of. If my ECM is fried, why would it have worked fine before replacing FPDM? I am at a dead end. Mechanic is at a dead end. Please help.
Old 03-08-2013, 05:46 PM
TANGO420's Avatar
TANGO420
TANGO420 is offline
ECM is fine. Had it checked, and nothing is wrong with it. Im going nuts trying to fix this. I dont know what else I can check.
Old 03-08-2013, 06:37 PM
Cofcmsc's Avatar
Cofcmsc
Cofcmsc is offline
So it is turning over and firing just no Fuel? When you say that the fuel pump is not turning on I assume that you definitely do not have any pressure at the rail. Is there a chance that one of the components that you replaced is faulty?
Old 03-08-2013, 06:47 PM
TANGO420's Avatar
TANGO420
TANGO420 is offline
Yes. Checked both pump and module. Both work according to mechanic.
Old 03-08-2013, 06:50 PM
TANGO420's Avatar
TANGO420
TANGO420 is offline
If I spray it with starter fluid it will start right up and run great. But it dies due to not getting ant fuel. No codes are being thrown. I have tried fuel inertia switch, fuses. I'm lost.
Old 03-08-2013, 07:25 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
Have you checked power and ground at the pump itself ?
Old 03-11-2013, 06:47 PM
TANGO420's Avatar
TANGO420
TANGO420 is offline
Ground at the pump was the problem. Thank you very much for this suggestion. You saved a possible heart attack. I now have my truck back and am extremely happy. Thanks again!!
Old 03-11-2013, 07:09 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
Happy to help. And thanks for posting the fix ! I don't like loose ,dead threads . It could help someone else in the future .
Old 03-11-2013, 07:27 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Happy to help. And thanks for posting the fix ! I don't like loose, dead threads. It could help someone else in the future .
Oh aint that the truth!
Stewart
Old 03-11-2013, 07:43 PM
TANGO420's Avatar
TANGO420
TANGO420 is offline
Least I could do was come and thank you. I was so busy lookin at all the difficult stuff I never thought to look at the easy answer. You saved me another tow and a bill from the dealership. Very grateful for you and this site!!
idlewild
1983 - 2012 Ranger & B-Series
08-10-2015 03:10 PM
Erie-S-Cape
2004 - 2008 F150
13
07-16-2015 02:09 PM
arich
15
04-23-2012 09:31 AM
georay
2004 - 2008 F150
04-19-2011 10:12 AM
MFP8055
02-01-2011 11:41 AM
Quick Reply: 2006 F-150 wont run
