super duty front springs in OBS f250 - Ford Truck Enthusiasts Forums
Old 03-08-2013, 01:29 PM
Leduc'sMopars Leduc'sMopars is offline
Leduc'sMopars is gaining momentum as a positive member of FTE.
I need to get springs for the front of my truck since the factory ones are worn out. I've been toying with the idea of super duty springs since my neighbor offered me a free new front pair. Can you use the SD springs with the TTB front axle that's in my f250? Any help or links to kits I can use is appreciated. I know lifting the truck and a front reverse shackle flip is required but I'm not sure if it would work with the TTB. Thanks!
Old 03-08-2013, 03:11 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
NO. You can only use them with a solid axle
axle swap and leaves question dylansf23 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 01-24-2015 05:04 PM
RSK, V Code, and Icon springs DIYiT 1987 - 1996 F150 & Larger F-Series Trucks 7 08-02-2012 07:11 AM
Dana 44 front end? TheTowingCowboy 1994.5 - 1997 7.3L Power Stroke Diesel 11 05-19-2010 06:13 PM
Front Swap Leaf Spring on F250??? blindboyth 1987 - 1996 F150 & Larger F-Series Trucks 3 10-18-2006 02:43 PM
super duty springs on 82 rusty350250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 01-23-2006 04:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
