Lost lights
03-08-2013, 10:46 AM
on
Lost lights
I lost brake lights and turn signals just in the rear. I thought it was because I fix the trailer plug but I pull the plug apart at the rear end and no power. I do have running lights.
03-08-2013, 11:35 AM
Okay, what have you done to troubleshoot this? As in, have you checked fuses as a first step?
03-08-2013, 01:39 PM
on
Yes all fuses are good and bulbs.
03-08-2013, 06:53 PM
how about license plate lights? I'm thinking something may have severed your wiring harness to the rear (basically just south of the gas tank)?
03-08-2013, 08:24 PM
It's possible that the bed lost ground. Time to break out the test light.
03-08-2013, 08:30 PM
Quote:
Originally Posted by
conoso
How do you know they're good? What did you do? The sooner you start being more specific, the closer you are to getting this fixed.
03-09-2013, 07:09 AM
Did you remove any ground wires from the body screw behind the light fixture ?
03-09-2013, 08:14 AM
on
teh turn signal switch could be bad as that's why there not working.
Corbin Hendricks
1999 to 2016 Super Duty
07-09-2017 06:03 PM
LI250
01-05-2014 05:32 PM
johnson2007
17
10-03-2011 08:24 AM
superduty2001
08-07-2010 12:13 PM
robhunt
01-23-2004 09:33 PM
