front rotors
front rotors
2000 f250 SD PS with 187000 miles going to have to change front brakes soon and will need new rotors as they told me last time that they would not be able to turn them again. I pull a boat that weighs approx 5500 lbs but only during summer (trailer has brakes) what rotors and brakes should I get thanks for the help
I got about 250k miles on a set of NAPA rotors. They had two grades of rotors so I chose the premium version. I never turned the rotors, just replaced pads. Eventually the rotors wore down near the min thickness cast into the hub so I recently put my OEM set back on. Only 60k miles on that pair so I hope to get another 180k or so before I need to replace again.
Applied Rotor Technology is a sponsor here, with some good reading on their site. OEMs seems to last a long time, easy for me to recommend them, but for similar coin I'd look at cryo's pretty hard. Maybe slotted, but not drilled. It's a truck not a sports car.
Received 3,090 Likes
on
Stay away from the ceramic pads for sure. Go with premium or oem with the rotors and pads. You'll be wasting your money if you dont. Ceramic pads severely overheated my OEM rotors on my "05 excursion, with no load. Trashed all and replaced with premium rotors and pads, noproblems after that.
2002 F250 Brake Problems
I'm new to the forum and really could use some help. I have a 2002 F250 Crew cab 7.3L PSD truck with 121k miles on it. I started noticing that while driving down the road the truck would slow down as if the brakes were being applied. One time it would be the front and another felt as if it were the back brakes. I had all the brake lines replaced, replaced the front and rear pads and calipers. I had this done at a normal commercial garage. The brakes kept doing the same thing but it was worse after the work was done. I have stopped many times at the side of the road with smoke coming off the brakes. They replaced the pads and calipers a total of 3 times on the front and back. Still no good. Finally they gave all my money back and I took it to a local Ford dealer. They drove it a total of 101 miles over a week and did not find anything. I pucked the truck up last Sunday and within 15 miles the front brakes started shaking the front end. I can slam the brake pedal a couple of times and you can feel the brakes ease up and act normal. I am not crazy and have several people witness the brakes who were with me. I joined FTE for help!!! Any and all help is welcome!!!
on
Thanks for the input!!! Going to have the master cylinder checked/replaced tomorrow. I assume that they will have to flush the system as well if it is replaced. The brake issues just started out of the blue. I bought the truck from a guy who rarely drove it. I was using it about every day for the first several months when I noticed just starting to become an issue. Thanks again!!!
00Dave
37
10-21-2013 09:33 PM
