New Brake Lines? - Ford Truck Enthusiasts Forums
New Brake Lines?
Old 03-07-2013, 08:57 PM
deyomatic deyomatic is offline
deyomatic is starting off with a positive reputation.
New Brake Lines?
I want to finally put my power dual master in my '60 but thought that it might be a good time to replace the brake lines while I've got it all opened up. Does anyone have a suggestion about new lines? Should I take it to a brake shop or does anyone have experience with any of the pre-bent lines in LMC, Mac's, Etc.?
Thanks.
Old 03-07-2013, 10:44 PM
transam525 transam525 is offline
transam525 is starting off with a positive reputation.
Most any restoration parts supplier for our trucks will have the reproduction brake and fuel lines. Personally, I order all my restoration lines from Inline Tube directly. They have pre-bent lines for most popular vehicles, including the 1957-1960 Ford trucks, available in original tin-coated steel or stainless steel versions. If your line isn't listed, send them your original. The original part will be 3D laser scanned then bent on an automated machine. Their reproduction fuel line for the 1960 F-100 was slightly off, so I sent them my original line. A couple weeks later I received an exact copy of my original line, free of charge (they probably used it to update their pattern). The only difference between the old and new was the lack of rust on the new part--everything was 100% exact. They will also make custom lines. Good luck with your project.
Tools Needed for Running New Brake Lines 52F1Gary 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 01-25-2015 09:02 PM
Steel brake line that feeds the rear brakes jbondi 1978 - 1996 Big Bronco 10 10-30-2009 05:16 PM
93 F150 Brake Diagram stangfan78 1987 - 1996 F150 & Larger F-Series Trucks 1 12-31-2008 02:34 PM
parts RobPStroker 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-07-2005 05:24 PM
brake lines ddurant 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 05-15-2003 09:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
