66 f100 352 oil pressure sending unit question - Ford Truck Enthusiasts Forums
Old 03-07-2013, 07:30 PM
maxduran maxduran is offline
maxduran is starting off with a positive reputation.
I installed power steering on my 66 ford 352 f-100, now the power steering bracket to the oil filter/oil pressure port is too close to mount the new electric sending unit to the oil filter housing. Does anyone know if the filter housing mounted on the engine block (held by four bolts) can be flipped 90 or 180 to accomodate the new style sending unit? Or do I need to put an oil filter relocation kit on it?
Old 03-07-2013, 09:39 PM
37 Ford guy's Avatar
37 Ford guy 37 Ford guy is offline
37 Ford guy has a good reputation on FTE.37 Ford guy has a good reputation on FTE.
Quote:
Without seeing pics, I'm just kinda guessing but usually one can come up with a combination of angled fittings and/or extensions for attaching the oil pressure sending unit to it's current location.
I don't think you can rotate the oil filter mount however some cars & other trucks with FE engines have the oil filter mounting at different angles. For example, I think the 390 engine found in Ford cars usually has the oil filter mounting at 90 degrees towards the bottom but I think using a full size oil filter on that unit in your slick would hit the crossmember. You would have to use a shorter filter.
Anyway, somebody should come along and confirm or deny what I said. In the meantime, if you could post a pic of your new sending unit, that might help us see what you're up against.
Old 03-07-2013, 09:50 PM
customcab66's Avatar
customcab66 customcab66 is offline
customcab66 is starting off with a positive reputation.
i got rid of the electic gauge and put in a manual one it even fit where the original gauge went with no cutting of the dash
Old 03-07-2013, 11:13 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
There are two types of FE oil filter adapters.
1) Filter mounts vertically (Passenger Cars).
2) Filter mounts horizontally (1965/76 F100/350).
Passenger Car type shouldn't be used on F100/350's, because when (not if!) the left rubber insulator breaks (common), the filter will hit the engine crossmember, splitting it open.* Not pleasant!
1965/66 F100/250 with optional oil/amp gauges: C5TZ-9B339-B .. Oil Pressure Gauge Sending Unit Adapter ~ Both the oil pressure and warning (idiot) light sending units thread into this adapter.
GREEN SALES CO. in Cincinnati OH has 15 = 800-543-4959.
* Alternative "Spin-On" oil filter to Motorcraft FL-1A = Motorcraft FL-300
1975/78 Mustang II: Ford "shoehorned" the 302 into the engine compartment, had to use this shorter FL-300 oil filter. There wasn't enough space between the crossmember and adapter to install the longer FL-1A
Old 03-09-2013, 12:32 PM
daveengelson daveengelson is online now
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Had simular problem with power steering upgrade on the 65 only differnce is the engine is a 302. Installed electric oil pressure, and kept the idiot using both sending units. Went to local auto parts store picked up, believe it's 1/4" pipe thread, measured to get the desired length, in my case came to about 2 1/2" and then attached a 'T' fitting making sure the thread count on the 't' were same for the pipe, and also for both sending units, seem to recall they are threads on pipe and sending units are different. If decide to go this route make sure to use steel pipe and not brass. Anyhow, food for thought??
Source for oil psi switch terminal??? Becky_is_a_66 1961 - 1966 F-100 & Larger F-Series Trucks 18 07-24-2015 05:16 PM
Testing Oil Pressure Sending Unit powells_f150 2004 - 2008 F150 0 06-30-2014 06:52 PM
Oil Pressure Sensor cyclone3565 1999 to 2016 Super Duty 11 11-12-2013 05:41 PM
oil pressure sending unit thread size? dsrtjeeper 1961 - 1966 F-100 & Larger F-Series Trucks 2 04-13-2012 09:49 PM
electrical plugs for the engine temp. sending unit and the oil pressure unit? Help!!!!!!! 1965F100(3onthetree) 1961 - 1966 F-100 & Larger F-Series Trucks 11 03-29-2012 12:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
