2005 F 150 Steering Problems - Ford Truck Enthusiasts Forums
Old 03-07-2013, 05:39 PM
rocky1 rocky1 is offline
rocky1 is starting off with a positive reputation.
Hey guys, any ideas as to why I'm having a hard time turning my 2005 F150 in both directions. could it be the steering box? its been going on for a month now and for a about a week it freed back up but is now stiff again. I noticed when I turn its hard but then for a quick second its free then gets hard again. other than the steering box I'm not to sure what it can be. Any suggestions would bee great. Thank you.
Old 03-07-2013, 07:54 PM
Marty's 97 F-150 Marty's 97 F-150 is offline
Marty's 97 F-150 is starting off with a positive reputation.
Chances are it will be the joint in the steering shaft from the column down. If you pop the hood you will see the joint, looks like a little universal joint, under the master cylinder. That joint gets dry and starts to get tight. Our fleet of trucks at work have had a lot of them go bad within a few years. Hope this helps
Old 03-07-2013, 09:38 PM
MickInOhio MickInOhio is offline
MickInOhio is starting off with a positive reputation.
Same problem here
I have an 06 and was just searching for a fix.
Marty, How hard is it to replace the part and do you have a part number ? I have the tools and know just enough to be dangerous with them .
Rocky , have you had a chance to take a look ? Let me know how yours turns out. Have to check mine out tomorrow.
Old 03-08-2013, 12:29 AM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
Why don't you support the front end on jack stands, have someone else start it up and turn the wheel while you look and listen and might see what the problem is.
Old 03-08-2013, 03:30 PM
Thanks Marty , dead on with the diagnosis !! I am a very dangerous man ,,,, with tools ! Soaked the u joints with WD 40 and seconds later it freed up. Will add some grease to it and get it to a mechanic for replacement when I can afford it, soon I hope,, Come on tax refund !
Thanks again.
Old 03-08-2013, 03:38 PM
Glad you found the problem. I don't think they're all that hard to replace if you have the tools to do it yourself. I've heard that they can be a bit of a bear to get off the steering shaft but other than that it's a straight forward fix
2005 steering wheel shake issue/steering box leak redrivergorge 1968-2013 Full Size Vans 3 Today 02:13 PM
Manual hub confusion johnhammond 1987 - 1996 F150 & Larger F-Series Trucks 0 02-17-2017 05:42 AM
86 F150 sloppy steering Tparkin99 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 05-22-2016 01:32 PM
steering issues bigbubba87 1999 - 2003 7.3L Power Stroke Diesel 6 12-30-2015 10:17 AM
Steering box adjustment. 79FordBlake 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-17-2010 12:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
