Check Suspension Light - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 06-01-2003, 10:02 PM
niscguy niscguy is offline
niscguy is starting off with a positive reputation.
Hello all. I am new here and was hoping someone could help me out. I have a 2000 EB, the check suspension light came on in my truck and I no longer hear my compressor turn on. Obviously I suspect the compressor but was wondering if there could be someother problem. I checked the fuses both inside and out and they are fine. I didn't know if there was a switch or sensor that may go bad and I could replace that instead of taking it to the dealer.
If I do take it to the dealer, and it is the compressor, how much should that cost? Can I buy a used or remanufactured compressor?
Thanks for any help you may give.
Old 06-01-2003, 11:14 PM
S C S C is offline
S C is starting off with a positive reputation.
I have a 97 XLT that has 4 corner leveling and my compressor went once right after the warranty. I took it to the dealer (I'm in Canada) and explained to them that the warranty just expired few weeks and few hundred km's ago and they did a 80-10-10 for me. Meaning that Ford will pay 80% of the cost, 10% covered by the dealer and 10% by me. The total cost was quite large and I ended up paying around $2-300. It has been a few years now and I am not sure how much it cost now. Good luck and maybe you can get your local garage to locate a used one in the junk yard, but no guarantees...
Old 06-02-2003, 09:11 AM
Thanks, I did a search and saw your post earlier. So this is what I can expect? What happens if I don't fix it? The truck rides fine no sagging or leaning.
Old 06-03-2003, 12:13 AM
S C S C is offline
Don't risk it ! When the compressor is not pumping the airbags, (well, in my case, the left rear broke while driving to the delership) and it costs another $600 (Cdn), which is about US$400. Not to mention the whole truck is lowered like you have your compressor turned off, but the ride is bouncy because the only thing that keeps the truck up is the shocks and they are not designed to take the load (even when the truck is empty). Better get it fixed.
Old 06-13-2003, 01:11 PM
Thanks for all your input. I took it to a buddy of mine who fixes police crusiers for the county. He went under my passenger side dash and flip a switch and presto, the pump came on. I did not know the air suspension had an on/off switch. Apparently my wife must have kick it off accidently. Talk about a relief. Thanks again everyone. David
04 expedition air suspension issues M.Summers 1997-2006 Expedition & Navigator 5 12-26-2014 11:51 AM
Need Air Suspension help jojo2003 1997-2006 Expedition & Navigator 37 12-27-2013 07:05 PM
Air Suspension issues Sledmamma 1997-2006 Expedition & Navigator 1 01-03-2012 06:42 PM
PLEASE HELP!! Air Bag Rear Suspension - 97 Ford F250 Lite Duty ballfan95 1997 - 2003 F150 4 06-12-2011 05:43 PM
2004 NAVIGATOR AIR SUSPENSION HEAD ACHE cesario6868 1997-2006 Expedition & Navigator 11 01-24-2011 10:26 PM
Tags
02, 1997, 1999, 2000, check, chk, coming, expedition, ford, light, lite, shocks, strutmaster, susp, suspension, suspention
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
