New injectors, turbo rebuild...runs great but won't restart!
I'll make this as brief as I can:
Anyone have any idea what might be wrong here?
I am at wits end trying to figure this out. Oh, and did I mention the truck has been in my buddies garage since Dec. 2nd.......not making his wife too happy!
Thanks in advance for any help!
Tom
- Installed new injectors; (Baby Swamps 150/146), and rebuilt turbo.
- Put everything back together about 3 weeks ago; started right up after 30 seconds cranking; took it out for about 10 miles; ran Great!
- Brought it back and died 2 feet from the garage door.
- Would not restart; made sort of loud knocking noise while cranking.
- Came back next day; checked HPOP level; about 1.5" below top; filled with oil; cranked for 30 seconds and started.
- Took her out for another 10 miles or so; ran Great.
- Brought it back; pulled into garage and turned her off. Went to restart after a few minutes.....no restart and same knocking sound..(no idea whether this knocking sound has anything to do with anything just thought I should mention it).
- Couple friends told me that I should install the chip that I bought with the injectors before starting again. (I purposely left out the chip so it would not be suspect if things didn't run right after installing the injectors)
- Went back to it 2 nights ago; temporarily hooked up the PCM after installing the chip. Cranked right over and ran smooth. Took it out for 20 miles this time and it ran Great!
- Brought it back, parked it and shut it down. Tried restart after 5-10 minutes....No Go and still with the knocking noise????
Tom
So far, after sitting for a day or so it starts up and runs like a dream. Then it just won't restart right away. Does that sound like a CPS? Sorry but I just can't get past the fact that it runs perfectly when I get it started and then just will not restart within 5 minutes or so after I shut it down????
Is it possible for the oil from the HPOP to leak down and end up in oil pan? I have filled the HPOP 3 times now but the Oil level on the dipstick is reading high. I even drained a quart off after the first time I ran the truck but it is still reading high??
Any oil you add to the HPOP reservoir is going to end up in the oil pan, so if you keep having to fill the reservoir, it is normal for the oil on the dipstick to increase.
That's what I was wondering too. The knocking sound could be from low fuel pressure. But you also need to sniff test the oil on the dipstick and make sure it doesn't smell like diesel. That could be another reason the oil level keeps growing.
Correct, the HPOP reservoir should not be leaking down, but excessive cranking can cause it to be low, so figure out if it's leaking down after sitting for a couple of days, or just getting low after cranking attempts.
Thanks for all of the responses so far! I really appreciate it. My truck sat for nine months before I gathered all of the parts and got motivated enough to install everything. Now it is killing me that after all of this time, work, & of course $$, I can't get the thing to run correctly!
You have given me some things to try when I get back at it tomorrow. Had a couple of local guys tell me that they think it is still air in the system so hopefully one of these suggestions works and I can get this thing back to hauling my Jeep!
Thanks again,
Tom
Thanks again,
Tom
[quote=F350-6;12934406]Use a air pressure gauge for a tire at the schraeder valve on the side of the fuel bowl. Check with key on for e-fuel, or while cranking for mechanical fuel.
What should the fuel pressure be when checking as you suggest? Would a digital air pressure gauge work for this?
Thanks!
Thanks!
