Coolant leak on top motor - Ford Truck Enthusiasts Forums
Old 03-07-2013, 12:30 PM
Mat J Mat J is offline
Mat J is starting off with a positive reputation.
98f150 4x4 4.2
Small leak spraying out of a steel pipe onto the front of the motor. This isn't my truck so I'm not very familiar with it but looks like there is a pipe that come from the water pump threw a bracket and y's and one end has a hose going to heater core n the other part is where the leak is I think it has a hose connected to it that goes to the intake. Only leaks when thermostat open.
I'm going to take it apart tonight n see what I find. Iv looked for a replacement part and found nothing so I am going to try n replace the steel pipe with hose.
Anyone else had this problem or have a fix?
Old 03-07-2013, 02:23 PM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
Take a look at this thread for the pipe assembly:
http://www.ford-trucks.com/forums/11...hat-it-is.html
Old 03-07-2013, 05:20 PM
Spotty Spotty is offline
Spotty is gaining momentum as a positive member of FTE.
I know on my 98...but a 4.6.... that tube is less than $20.00 bucks at Rock auto. Also scroll to "Cooling"...the first item is water outlet O-ring...that may be the item in question in that thread that Torky 2 is linking...not sure though.
Old 03-08-2013, 12:14 AM
The 4.2 V6 is a pushrod engine, but they do some odd stuff on it, like having a water distribution pipe with an O-ring on the end of it that presses into a spot on the water pump.
It's as if the designers of the 4.2 V6 were feeling left out, since they weren't working on the Modular Engine Program, so they decided to go their own way to be different.
Old 03-08-2013, 12:30 PM
I got the part off advance auto can get the part for 125 but I am just gunna weld it up at work. Def a stupid design plus should be made of better material. I got an oring outta a kit no parts stores had it. Also rock auto only sells the motor craft part now and had two different ones listed w no pictures so I didn't know what to get.
E150 Mark III sschevel 1968-2013 Full Size Vans 16 05-16-2016 10:52 PM
P/N help please JaySVX 6.0L Power Stroke Diesel 10 10-08-2013 02:42 PM
Transmission Line Leak TMattson 1997 - 2003 F150 2 02-14-2010 10:27 PM
Holy Smoke! WAZZAT? Thomas Fore 1961 - 1966 F-100 & Larger F-Series Trucks 6 08-26-2005 11:02 AM
efi heater hose routing mauicruza 1966 - 1977 Early Broncos 2 03-16-2005 04:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
