Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 03-07-2013, 08:24 AM
rvpuller's Avatar
rvpuller rvpuller is offline
2013 Ford F-350
rvpuller has a very good reputation on FTE.rvpuller has a very good reputation on FTE.rvpuller has a very good reputation on FTE.
Hope this works out
Getting close to ordering a 2013 6.2 SC DRW 2WD 4.30 gears Lariat with all the goodies. The tow rating is 15600 and that's what GVW of the trailer is so I will be at the max but my 2000 V10 was only rated at 13K and it's done fine for the last 12.5 years. I've looked at the power curves that Mike had posted for a V10 with PI heads and it's very close to what the 6.2 puts out at the ground not the Flywheel so I'm sure I will be happy with it. Now I just need one more price from a different dealer to make sure the deal sounds right and I think it will be a go
Denny
__________________
2013 F350 Lariat SC DRW 2WD 6.2 4.30 Gears Air Lifts 50 Aux tank
2003 HH Premier 35 FKTG
Retired 2000 F350 Lariat SC DRW V10 4.30 Gears BrakeSmart
Air Lifts 4X2
  #2 (permalink)
Old 03-07-2013, 09:01 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
I don't think you'll be disappointed.
I haven't seen too many 2wd's, can't wait for the pics.
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #3 (permalink)
Old 03-07-2013, 10:00 AM
Mmaxed Mmaxed is offline
Garage is empty, add now
Mmaxed is gaining momentum as a positive member of FTE.
Have you thought about steeper gears if they are available in that rig? I know with my '08 V10 towing a similar load, I would get 4.88 or even 5.?? if I was towing all the time.
__________________
2008 F-250 Lariat, CC, LB, V10, 4.30s
  #4 (permalink)
Old 03-07-2013, 10:07 AM
rvpuller's Avatar
2013 Ford F-350
I just received a second price and they beat the other one by $1000 so I'm really getting close. There was a black one in a parking lot in Quartzsite just like the one we want and it looked sharp and low to the ground (works better for pulling 5th Wheels). I just wish I could find a good photo of one in Kodiak Brown and Pale Adobe two tone.
Denny
__________________
Air Lifts 4X2
  #5 (permalink)
Old 03-07-2013, 10:13 AM
rvpuller's Avatar
2013 Ford F-350
Quote:
I ran rpm and speed calculations and with 4.30 and the 6 speed transmission and 4.88 would be overkill. You have to also remember there is no longer a 1 to 1 gear and two overdrive gears that allows the transmission to keep the motor in it's power band.
Denny
__________________
Air Lifts 4X2
  #6 (permalink)
Old 03-07-2013, 02:51 PM
2011 Ford F-350
The new trans is nice, lots of flexibility with manual, tow/haul, etc. I'm assuming you've already test driven one so I probably won't have to explain the huge improvement over the 4R100.
__________________
Matt
  #7 (permalink)
Old 03-07-2013, 03:58 PM
MexicanScaper987's Avatar
MexicanScaper987 MexicanScaper987 is offline
MexicanScaper987 is a name known to allMexicanScaper987 is a name known to allMexicanScaper987 is a name known to allMexicanScaper987 is a name known to allMexicanScaper987 is a name known to allMexicanScaper987 is a name known to all
Joe Yarmel
Can't wait too see pics of the new rig!
__________________
Joe- PA Chapter Member
2000 F350 4x4 S/c LB 7.3L, 6637, Auto Meter Boost, EGT, & trans temp gauges, 6" CAT Stacks, ION ALLOY wheels.
July 5-7 2013, Pre RRE GTG info http://www.ford-trucks.com/forums/12...l#post13263496
  #8 (permalink)
Old 03-07-2013, 05:18 PM
judithgap's Avatar
judithgap judithgap is offline
judithgap is starting off with a positive reputation.
Like Silverbullet said I think you will be pleased with the 6.2 with the 4.30 rearend. I have had my 2013 F350 4x4 for about 3 weeks now and love it.
Traded an 08 6.4 diesel and have still been impressed with the power of the 6.2.
  #9 (permalink)
Old 03-08-2013, 08:12 AM
rvpuller's Avatar
2013 Ford F-350
Quote:
No I haven't test drove one but the group we where traveling in Mexico had 3 2013 trucks but with the 6.7 so I got some seat time in the new ones. The only question I have about the 6 speed can you shift it in and out of manual when you are on the go. There's a lot of times now that it would be nice to be able to lock it into a gear when pulling to stop it form hunting for gears on small grades. I know it will be a improvement over the 4R100 with the added 2 gears and closer ratios.
Denny
__________________
Air Lifts 4X2
  #10 (permalink)
Old 03-08-2013, 08:34 AM
2011 Ford F-350
Quote:
Denny
You sure can. When you drop it into M, it'll stay in the gear you were currently in when you were in drive.
Another "nice to have" thing is that if you're using Tow/Haul in D and flip over to M, drop a few gears or whatever, when you flip back over to D, it'll keep your Tow/Haul engaged.
__________________
Matt
  #11 (permalink)
Old 03-08-2013, 10:55 AM
rvpuller's Avatar
2013 Ford F-350
We just made a counter offer on the truck so we should know soon
Denny
__________________
Air Lifts 4X2
  #12 (permalink)
Old 03-08-2013, 12:28 PM
rvpuller's Avatar
2013 Ford F-350
Done deal it's on order and I only had to talk to a sales person one time to give him a credit card number everything else was done online between the Ford build site and email. It should be in a week or two after we get back to our homebase in late April
Denny
__________________
Air Lifts 4X2
  #13 (permalink)
Old 03-08-2013, 01:16 PM
2011 Ford F-350
Nice, congrats!
You should ask the dealer for a copy of the order (it's called the DORA). Once you get that, compare it to the 2013 order guide, make sure everything you asked for was ordered and nothing was added or left out!
__________________
Matt
  #14 (permalink)
Old 03-08-2013, 02:48 PM
rvpuller's Avatar
2013 Ford F-350
Nice, congrats!
He just sent it to me and it's all there.
Hot sure I'm going to now how to act with a truck I can talk to
Denny
__________________
Air Lifts 4X2
  #15 (permalink)
Old 03-08-2013, 04:26 PM
fordmdb's Avatar
fordmdb fordmdb is offline
PREMIUM SPONSOR
fordmdb has a very good reputation on FTE.fordmdb has a very good reputation on FTE.fordmdb has a very good reputation on FTE.
Congrats on the new tow rig
__________________
Custom Tuning for F-E-Series Engines 6.8L V10 / 5.4L V8 / 4.6L V8 / 6.2L V8 / 5.0L V8 / 3.7L V6 / 3.5L EB and more!
SCT Custom Tuning Dealer
www.5startuning.com email me here:mike@5startuning.com 843-536-1244
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
