MAF calibrator vs hand-held preogrammer
I've never used a handheld programmer and have no knowledge of their operation, i am sure the handheld units off more adjustments but curious if the extra adjustments are worth the added expense over a MAF calibrator, whole bunch of money less but they don't have all the bells and whistles for you to play with..
Air/Fuel Calibrators
Underdog Racing Development
on
Hopefully this is not for the truck in your garage because none of this will apply.. it doesn't have a MAF meter and cannot be tuned with a handheld device.
The MAF "calibrator" is a device that attempts to fool the computer, sometimes this works OK if the particular engine combo only needs a small amount of "foolin" but if it's heavily modified from stock the computer will have to use up most or all of it's adaptive range to make corrections.
A computer tuner will allow you to change the MAF transfer function in computer memory so regardless how radical the engine combo the computer will make accurate calculations the first time around and therefore won't have to make as many corrections. A tuner will also allow you to change trans shift points and just about anything else technically.. though some tuners limit what you have access to.
speed density or MAF
Hi guys can someone tell me how I can tell what system my truck has on it I have an 1990 F350 XLT Lariat CrewCab 460 EFI E40D trans I am in Australia and info is very limited over here I rely havily on these forums
thanks Adam
The MAF equipt 460s are rare even in the US. They were only made in 1996/7 and are California emissions or 50 state models only. 1990 will be a Speed Density Bank Fired system. The MAP sensor sits on top of the AC casing near the engine and will have a 1/4" plastic vacuum line to the rear of the plenum and a 3 wire plug.
BAP = MASS Air
MAP = SD
OK, that would be the first time I heard a MASS air system not having that sensor. It could certainly be correct. I wouldn't know how the PCM would get that information, maybe another sensor? Or maybe it doesn't need it, no idea.
If Summit Racing is accurate, I see a MAP and a BAP for the 460 and year 1990
http://www.summitracing.com/parts/sm...-size/7-5l-460
http://www.summitracing.com/parts/su...-size/7-5l-460
I'd say you're correct then. I also found this - Fuel Injection Technical Library » EEC Program Codes
At the bottom it has the 7.5L and they are all SD.
Ok thank you guys for your help on this very much appreciated I guess I have a speed density system then because I have found the MAP sensor and it has the small vacuum line on it from the manifold and three wire plug and I do not have any air intake tubes as mine has had a LPG mixer fitted in front of throttle body EFI stuff is very hard to find over here in Australia and the speed shops only deal with carb 460s so where can I get a set of exhaust flange plates to suit EFI Heads I have carb 460 headers that I want to fit to my EFI 460
Regards
Adam
Regards
Adam
