351 Cooling system...some quick advice
Hi there,
'82 F100 351c with AC
I have a few symptoms showing up during hotter weather. On a normal cool day my temp stays fairly constant at the lower end of the "N O R M A L" temp gauge. No issue there.
But on a hotter day...we commonly get 90+...the truck is struggling once we leave the highway. Traffic lights, etc around town quickly cause the temp to go past Half on the guage!
I believe my thermal fan clutch is not working as I have never heard it "roar up" on a hot day... so I will be replacing that along with a professional clean and flush (including new themostat). But my real question is, will a properly maintained system along with a working clutch fan be sufficient to keep my rig cool, even during slow speed around town?
Have toyed with the idea of electric fans but would rather keep standard setup if possible. I want to be able to drive it regardless of weather and not stress if I have to go into town.
Thanks.
Thanks.
Hi there,
Thanks.
Thanks.
If your AC is factory instead of add-on.. you will have the bigger radiator,etc for it..
If it were me, I would make sure that it is REALLY a problem BEFORE spending a lot of money....
By that, I mean I would put a MANUAL temp gauge on it to be sure that the factory gauge is correct..(they have been known to be unreliable).
You could hook one up temporary or permanent and check it against the factory gauge...
If you have a 180 or 195 thermostat, the gauge should read somewhere around the mid scale reading...after warm up...
It it comes up to three quarters of the gauge when idling,traffic,etc..Especially in hot weather where you are now...you can check the actual temp....
If you are running around 190 to 200 you are Ok...
If not, then isolate the problem...Fan clutch,thermostat,water pump, hoses soft and collapsing under acceration(lower hose), bugs or trash in radiator and condenser fins...
After you get it warmed up, bring the engine up to about 2000rpms or so and take a shop towel and throw at the front of the condenser in the front of the radiator...If you have good air flow, it should suck the towel up against it....IF not...blow out(from the back side always) the radiator and condenser...
This will tell you whether or not you're pulling enough air through...
Hope this helps you....I like to find out where the problem is before I spend the money.....Trav..
Ditto on making sure you have a problem. As Trav said, the factory gauges are notorious for having problems. I put a mechanical gauge on. Also, if your radiator cap is bad you may lose coolant and then suck air back in as it cools. Then it gets warmer and pushes more out, sucks more air in, etc.
This is a general rule that works good on getting someone pointed in the right direction when troubleshooting cooling problems;
If it overheats in stop and go traffic, that is generally a air flow problem.
If it overheats on the highway, that is generally a coolant flow problem.
So using those rules, you are on the right track thinking it's the fan clutch, which would not give you good airflow if it were faulty.
Thanks for the advice. Just received the clutch today, but have a problem. When I opened the box, some of the internal fluid has leeched out of the clutch while it has been sitting upside down. I'm pretty annoyed that it wasn't marked "this side up".
Is some fluid loss ok or should I get it exchanged? The bag with supplied bolts was also quite slimey.
annaleigh
12-27-2015 08:35 PM
adambird
11-14-2008 01:06 PM
natewoz
19
02-09-2008 11:36 PM
JimTZ
10-26-2007 03:21 PM
