Need info on 1959 factory flatbed
I think I have exhausted all other search methods trying to find information about the factory flatbed on my 1959 ford f-250. I found the truck out in an old shed in southern washington and couldn't resist asking about it. Later that day i drove it home for $700 dollars. I thought that was a steal. All original, 223 I6, 3 speed manual on the column, almost no rust (little on the cab corners) even still had bias ply tube tires on it with what must be the original spare.
I have started my restoration and have a question...
What did the tail end of a pickup look like with a factory (or dealer installed) 7' flatbed on it? It has FORD stamped in the back (not script). If anyone has pictures that would be great! Hours on google have gotten my no closer. I would like to find out what kind of tail lights are supposed to go on it and how they were mounted. I assume they were the shield type. Also any other details about the factory flatbeds would be much appreciated!
I cannot tell you much about the bed itself, but the tail/stop lights could have been one of several types. One type would be the "shield" type of Ford lights mounted on the same brackets as used on the F500 and F600 trucks. Left side lamp would have a window for illuminating the license plate, and a license plate bracket.
I have also seen the generic round tail/stop lights used with the same kind of bracket.
The brackets bolt to the frame, and the lights are outboard of the frame. Sorry I do not have pictures.
Welcome to the fridge world. My 59 F350 had a very similar bed but with the 'ford' in script. I intend to put it on my '37 1 1/2 ton as it has a homemade wooden bed and I put a 9' flareside box on the '59. It's too dark to go out and look now, but from this photo I already have it looks like it had the shield tail lights. They were in really rough shape, but tomorrow I can get a photo of what they are. Looks like your bed is in nice shape. Hey, that's a Washington plate!
Your flatbed is the only other I have seen that has the wood spacer between the frame and the bed, although mine on the right side at the back has a space for the spare tire to slide in from the right on top of the frame.
Thank you for the picture! I am fairly certain now that shield taillights would be appropriate for my pickup!
Now all that remains is to figure out where this flatbed without script came from and what the tail end was supposed to look like (below the rear end of the flatbed).
Those light brackets look original, so the shield type should bolt right up. Often those brackets get bent over the years, so a little straightening can help make sure the lights point straight back. When you get the lights, get the license plate bracket that fits the back of the light for the "factory" look.
On the bed, the FORD in block letters might mean this was a dealer or upfitter installed bed, which was common. The back of the bed looks pretty original - just the end of the frame and frame crossmember. Often, a piece of angle or bar was welded at the end of the frame so a hitch ball could be mounted or a pin hitch for a farm wagon could be used - it looks like yours has that. Also, the "bumpers" on the back of the bed look as if they were part of the bed installation.
