2007 Navigator power liftgate and power latch not working - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 03-06-2013, 07:36 PM
Jaylegger Jaylegger is offline
Jaylegger is starting off with a positive reputation.
Hi everyone, I need some thoughts on my liftgate issue that began today. I opened the gate normally, the latch whirred (unlocked ) when I pulled he lever and the gate opened, I then shut it but it wouldn't latch, the latch mechanism will not stay in closed position nor is there any electrical noise to indicate it's even trying. I then checked the power liftgate and nothing works there either, not via the button inside the gate, the console button, or the remote.
The latch mechansim itself moves freely from the open to closed positon but won't click lock closed.
I've checked and test for continuity all appropriate fuses inside the vehicle and engine compartment and they are fine. Regardless I essentially have lost power to both the latch and the powerlift which are two different circuits. I'll be checking connector C4339 in the tailgate tomorrow but in the meantime does anyone have any thoughts as to what may be causing this?
Thanks.
Old 03-10-2013, 09:44 PM
Problem somehow fixed itself, all is good.
Liftgate Ajar ['04 Navigator] salazar44 1997-2006 Expedition & Navigator 2 01-02-2017 02:48 PM
Power Liftgate won't open by remote but does open/close using dash button?? Brent Riley 2007 - 2014 Expedition & Navigator 1 12-09-2016 12:55 PM
liftgate ajar the-pred 1997-2006 Expedition & Navigator 2 08-17-2016 05:57 PM
2010 Ford Escape rear liftgate won't open tino22 Escape & Escape Hybrid 7 06-07-2014 07:54 PM
whacky liftgate jawdoc 2007 - 2014 Expedition & Navigator 3 06-07-2013 05:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
