Stacks good idea?????
I have a 2000 250 7.3 and I am thinking of replacing the stock exhaust with a set of stacks. 4" down pipe from the turbo to a 4" inlet y pipe with a 5" outlet. two stacks 5" to 8" the only reason I am thinking of do this is that I am getting the whole set up for 140 and it all only has 5000 miles on it. Would this be a smart move? What are some of the pros and cons
Well I myself am not a fan of stacks. Personally I think they belong on big rigs and Dodges but then again I am an old guy.
Pro's: cheap exhaust system and you will be able find your truck in a Walmart parking lot.
Con's: You'll need to stack your stacks and put put huge tow mirrors on it.
It will be real easy for the cops find you in traffic and hassle you.
Rain can and will get in them unless you have caps or flappers.
Basically it boils down to personal taste.
As long as you remember, it's for the sake of impressing you. There won't be an audience shouting cheers... more like people living their lives, looking at the source of the noise when you pass, and saying "Jeez". The tubes will be behind your back when you're driving, so you're not looking at them. You're stereo is just drowned out by them (not exactly for a long drive out of state). Women aren't typically impressed, they normally just tolerate them... sometimes not even that. It's a costly mod if you ever sell the truck... it really whacks the value.
It's like a tatoo... sometimes a person likes it their entire lives, other people say "What the hell was I thinking?"
Had stacks on a truck I owned, came from factory like that (Dodge).... Looked good and sounded good for a couple of years. Then the maintenance started getting out of hand. Lower pipes and mufflers rusting out all of the time from water getting in. Vibrations from the cab to bed movements made for a lot of exhaust leaks. Blow soot all over the bed and upper wheel wells, had to clean all of the time and over time messed up the paint. I loved the truck but she was a high maintenance girl because of her stacks.....
