Front Bumper removal?
on
1 Post
I am replacing my bent OEM front bumper. Anybody got tips or instructions? While I'm in there I am going to replace my broken fog light brackets. Had a chance encounter with a Deer, dead center between the tow hooks.
Thanks for any advice so I can avoid some skinned knuckles ! I won't be back on line till late tomorrow but will check for help then ! Thanks in advance.
Don't forget about the two side braces on the ends behind the bumper - one bolt per bracket on each end. A second person is a great help when you break loose the last bolt, and the bumper really is not heavy at all, just very awkward.
On re-installation, I personally use a 1/4" thick X 1/2" wide X 10" long piece of wood as a spacer to get an even gap between the bumper and hte grill & head lights. I place the stick under the inside corner of one head light assembly and push the bumper up until it holds the stick in place... then tighten one bolt on that side's tow hook and set the gap on the other side the same way.
Before tightening all the bolts, though, also check your end-to-end alignment with the fender panels and make any necessary tweaks to your alignment accordingly.
Then, tighten the four tow hook bolts and the two end bracket bolts and your done.
on
