2 new codes.. need some help - Ford Truck Enthusiasts Forums
Old 03-06-2013, 05:42 PM
72Highboy4x4's Avatar
72Highboy4x4 72Highboy4x4 is offline
72Highboy4x4 is starting off with a positive reputation.
Ok, so this past week i towed my 72 f250 to IL from CA. 2100 Miles. 6100#s with the trailer. No problems at all. Got about 9 MPG too the whole way. Ok, so here is my problem now. As some of you may know, IL just got about a foot of snow. Its all slush at this point. I am living in the country right now so i drive thru alot of it. Ok, now you know the back story, today i drove the truck to my brothers house, put it in park and bam! check engine light came on. About a half hour later i drove it to AutoZone and had them check the codes. Here is what they pulled.
P0705
P0171
Hope you can help me out Bluegrass, tell me what to replace. I have to drive it back to CA in 4 days... Thanks for any/all advice guys
Old 03-06-2013, 07:20 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
First, Il. is not in good shape as a state but Ca is going broke.
Get ta heck out of Ca.
705 is a Trans shift select error.
Possibly from the snow. Look over the harness connector and dry it out.
The 171 is lean bank 1, the driver side.
It may be a one cylinder missfire issue.
Only way to look at this is with a Scanner to view live data for fuel trims and mode $06 test 53 allows you to look at the misfire counts for each of the 8 cylinders to possibly see one with a high missfire count.
Or an air leak on that bank for some reason.
I have cylinder 5 in my truck with high missfire counts but it's not bad enough to shift the fuel table out of limit yet but the fuel trim does show higher than the other bank so it's a good bet. It's plug, boot and maybe coil time to head it off at the pass.
"Ain't Scanners wonnerful" crystal *****?
A hint: If the missfire counts are in hexadecimal and you want to know the count in decimal, use your computer calculator program to do the conversion otherwise the scanner should tell you the count is just high.
Good luck.
need help identifying this huge ford truck Reshel 1961 - 1966 F-100 & Larger F-Series Trucks 14 09-30-2006 08:32 AM
P0301 Code - Thanks for the posts! krewzn_along 1997 - 2003 F150 8 02-25-2006 12:37 PM
IL lift law questions??? clearedforlandin Illinois Chapter 15 01-03-2006 09:19 PM
NEED HELLP NOW PLZ im srcewed 24 pack for the one that helps fix!! SilverDually 1999 - 2003 7.3L Power Stroke Diesel 16 10-17-2005 08:03 PM
Want to Share my X and Awesome Websites for your Expedition actfsu 1997-2006 Expedition & Navigator 5 09-12-2002 12:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
