truck specs
truck specs
does anyone know where i can find truck specs without having to pay for them, i just purchaced a 1988 f350 4x4 crewcab SRW longbed with a 460ci. and would like to know more about it. (axle ratio, eng rating, options etc.) i was able to check my vin online but was only able to find out where it was built and confim what engine it came with.
thanks in advance.
thanks in advance.
Received 3,101 Likes
on
thanks in advance.
thanks in advance.
all the specs are on the tag on the driver side "B" pillar. take the codes, and post them here. someone will decode them for you.
Best way I know of to find optional equipment information is to get an original brochure. They're cheap, and fun to have.
on
1988 Ford F-350 Crew Cab 4WD VIN 2FTJW36G2JCA95678 - Free Ford F-350 VIN Decoder
that will give you the basics.
give me the codes on the tag and i will give you all the truck info. i have the 88 service manuals with all the code breakdowns.
on the sticker in the door i see the vin, weight,gvw, etc. and long the bottom there are 7 spaces with seperations. cant make out the wording to small but im assuming these are the codes your refering to.
168 / W361 / SBD / K / C5 / / 8F
that 6 digit was blank on the sticker also. i tried taking a picture of the decal but it was to dark out by the time i got home. let me know if this help.
on
168: wheelbase in inches
W361: F-350 4X4, 9200lb GVWR
SBD: cloth seats, regatta blue, crew cab
K: C6 automatic transmission
C5: 6250lb rating 4.10 gear ratio
8F: spring code. E5TA-5310-NA front spring, E7TA-5560FA rear spring
the blank 6th position is for external body tape stripe color. no code = no stripe from factory.
thankyou very much!!!!!!!!!!!!!!!!!
on
seth_85
01-23-2006 03:46 PM
bigbluef73
09-08-2003 01:02 PM
