2008 F450 w/6.4, White Smoke from exhaust?
I have a 2008 F450 with the 6.4 diesel engine, about 60,000 miles. The other morning after a solo (no RV) short drive, I noticed a puff of white smoke out of the exhaust pipe. That was the first time I noticed it and it has not done it since then. What could it have been and is it something I need to be concerned about?
Can't say if it was on a regen, some times theregen just flashes up on the console for a second or two and you don't see it. Does the regen system throw a puff of white smoke on occasion when it kicks in?
Don’t see any antifreeze either dripping tothe ground or on any of the hoses and stuff. The entire cooling system was replaced about a year ago under warranty.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Same thing happen to me. Called the Ford garage I think he said something about there being an exhuast sensor that causes this on the 6.4. Anyways he knew what I was talking about and fixed it. Wasn't long after I removed the DPF so I'm not sure if it was truly "fixed". But FYI without DPF there has been no white smoke.
Mine frequently throws a white cloud of smoke during regen but not always. It's usually when accelerating from stop.
I monitor regens now via my ScanGauge2. EGT over 575 means regen. Regen during a tow soars past 800.<!--?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
[/quote]
Mine frequently throws a white cloud of smoke during regen but not always. I usually see it when taking off from a stop.-->
[/quote]
My 2010, 250 does smoke too. Been to the dealership many times for this problem. Never happens below 15 degrees F. Always when engine temperature is at normal, blue/white smoke, very heavy.. Sometimes I feel like 007 or an A1M1 Abrams tank with a smoke screen capabilities. No loss of coolant, no coolant in the oil. No loss of power or misfire. The dealership replaced the air charger, which I would have called the intercooler, because there was a TSB that described my conditions almost exactly. But after 1 week it returned.
The first time I called the dealership the said I brought the truck in for the same problem 9 months earlier. Ha, I didn't own the truck then, that was the first owner. At that time the EGR was replaced. I'm threatening lemon law, and will pursue it if necessary.
So my question is has anyone else had this problem and if so what was done to remedy the problem?
It is condensation that buildups up over time.
Sometimes an occasional WOT will help to keep it clear. Lots of towing also helps to keep it cleared out.
then the other issue of smoke at the start of a regen is another one of those events. Separate issue from the water in the cac issue though. Some have the smoke at the start of a regen and some don't. It is generally considered normal to due cold exhaust system..but over 160F enine temps at the start of the cycle.
Well, as stated earlier, the dealership just replaced the air charger (looks like a new intercooler,first radiator type rig in the front)and within 1 week the rig began to show its smoke signals.
It's not bad for me, the operator, but the poor folks behind me that worries me. If there was a way for me to upload the 58 second video I made last week, I'm sure it would raise some eyebrows on this site.
The atmosphere in CT. now has been very dry, 17-30% humidity. In one week I don't believe that there could be enough moisture to resurrect this problem.
As for the regen, it now comes on after the first sign or puff of smoke. It stays on for 20 miles until I arrive home and then have to shut down even though the info panel says "Drive to Clean". This is something new since the replacement of the air charger.
Just some observations, while driving, and smoke begins I can come to a stop and the smoke will stop. It may not restart when driving resumes or it may start immediately after driving begins. Oddly, if I place the gearshift into neutral while the truck is still moving the smoke will stop and begin as soon as I get into drive (carefully bringing revs back to an appropriate level).
Okay, call me a rookie, what is WOT? Whaling On Throttle? Unfortunately, the truck was bought to tow our camper trailer, 33' long, but that only happens a few times a year. It has become my daily driver. I feel fortunate that I get 12.8 mpg after reading some other posts. It goes down to 10.5 mpg while towing, still not bad.
Is there a place to upload a small video being a free member?
Well, got to take the trailer to the dealership to have the spring opening and review before the one year warranty on workmanship is up, and I do have a few things that have to be repaired. But that being said, it's not far enough to put a whoopin on the throttle, nor hilly enough to spin the turbo's to a full 30 psi for an extended period.
But honestly, when I bought the truck last year, the regen took ten minutes. Now I drive 20-30 miles and it's still on. BUT, the truck smokes like a chimney without the info panel calling for the regen to happen. Odd, definitely! The Ford dealership has checked the OBC to see if there were any codes to indicate the presence of any trouble, nil. They're baffled too.
I'm trying to be patient, but if I'm towing my camper for 300 miles to Bar Harbor Maine, and the trailer fills with smelly, un-burnt diesel fumes, my children will never enter the camper again. I'm not sure what your financial status is, but I can't take a 50K hit for a unwanted camper trailer, and a 4 door fuel hog.
If I'm pushed much further, and it still smokes I'll have to pursue the lemon law. Here in CT.,it covers the warrantee period which with the 6.4 diesel is 100K. If I keep filming everytime it happens, they my believe me that its a hazard to myself, my family and those following behind me. Not to mention the environment. I was always told diesel was cleaner than other internal combustion engines.
C'mon, this has never happened before to any other F250 or 6.4?
