Lincoln Navigator - Ford Truck Enthusiasts Forums
Texas Chapter Join Chapter, Leader: LibTimothy
Lincoln Navigator
Old 03-06-2013, 05:46 AM
blughost blughost is offline
blughost is starting off with a positive reputation.
Lincoln Navigator
I have a 98 Nav and it starts great with no problems. The only thing is it stalls while idling and i know its not the transmission or the relay. What are my options?
Old 03-06-2013, 06:49 PM
DRRXR's Avatar
DRRXR DRRXR is offline
DRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputation
Guess and a wild one- if there is no check engine light then I would guess the IAC. That would be the easest of problems to fix.
Old 03-06-2013, 11:01 PM
Snuggyworm's Avatar
Snuggyworm Snuggyworm is offline
Snuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to behold
sounds like the butterfly valve, or IAC. idle air control? yeah, if tat thing is dirty inside or u gots a leak, then it'll affect ur idling and ur gas mileage too. i remember this cos i helped replace that butterfly valve on a crown vic. if the sensor or motor is out on the butterfly valve, i think there is no part for tat. u might have to buy the whole butterfly valve. but clean it up and see if it fixes the problem first.
Old 03-06-2013, 11:03 PM
Snuggyworm's Avatar
but if u do have a check engine light, go to o'reilly's or autozone to scan for the code. with the code, it's much easier to pinpoint the solution to the problem.
Topless wpnaes Excursion - King of SUVs 26 07-15-2013 09:18 PM
Where is serial # on 1946 or 47 half ton pick up? Trulyvintage 1947 and Older Ford Trucks 3 05-20-2011 10:40 AM
so whos ready for snow? nflfreak43 Tennessee Chapter 101 02-10-2010 12:47 PM
I need HiSPL Testing..... 3 08-19-2009 05:52 PM
how do I know if I have a 400 Ford_Six 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 11-13-2002 08:45 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
