1960 Super Duty Crew Cab build thread
#138
on
The following users liked this post:
#139
#140
on
#141
on
#143
on
#144
on
#147
on
Newly made rubber air brake hoses from the cans to the valves, front and rear all the same. New copper-nickel hard lines run from one tank to the spring brake valve and out to the spring brakes. New copper-nickel fuel line from the refurbished gas tank to the engine. Also ran the same hardline from the new clutch master to the slave cylinder, and from supply air to the air horn.
Judging by the DOT tags on the old air hoses, and the stamps on the nylon spring brake lines, the brakes had been worked on in January, 1979.
