diff between SD and HD, also oil capacity.
Old 03-05-2013, 10:38 PM
Gembone's Avatar
Gembone
Gembone is offline
I just picked up a 70 F100 Flareside with a 300 i6.
PO says the motor had been swapped with a HD 300 from a SWAT van.
Sticker on the valve cover says its HD from 74-75.
I also know you can't trust stickers on easily swapped parts.
First question is how would I tell the difference between the SD and HD engines.
Second issue is I have put over 5 quarts of oil in it and it doesn't even touch the dipstick.
Does it hold over 6 quarts and is the dipstick the proper one for the engine?
# on the dipstick is 14045832 W
Thanks for any light you can shed on these issues.
Old 03-06-2013, 10:44 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
I believe the differences between a regular 300 and the HD version were all internal [crank and possibly lower compression pistons]. The external difference would be the exhaust manifold. The outlet points straight down rather than angled toward the rear and measures 2 1/2".
I would be surprised if the oil capacity exceeds 6 quarts.
Old 03-06-2013, 10:59 AM
Gembone's Avatar
Gembone
Gembone is offline
OK then. I will have to assume that the dipstick is not the correct one.
I have the MPC but was unable to find the part number for the proper one.
I might have to get it with tube. Unless someone knows the proper length of the dipstick.
Then I could get a generic one and cut to length.
Here is a pic of the manifold. looks like it is the SD from your description. (unless they kept the original manifold)
No way to know for sure without a tear down I guess.
Old 03-06-2013, 11:23 AM
1986F150six
That is a standard exhaust manifold [not HD].
The dipstick seems to be sticking way up... can you get a photo from the driver's side?
Old 03-06-2013, 11:33 AM
Gembone's Avatar
Gembone
Gembone is offline
here is from drivers side and where it goes into the block.
I know you can't always go by stickers but got the valve cover ID sticker.
Old 03-06-2013, 12:13 PM
1986F150six
You had previously mentioned that the replacement engine came from a van. That would explain why the dip stick is angled toward the front... imagine the engine being recessed in the van.
Here is a link to a vendor who sells reproduction HD exhaust manifolds, so you can see what the HD unit looked like.
300 4 9 Ford Heavy Duty F600 F700 New Exhaust Manifold | eBay
Old 03-06-2013, 12:42 PM
Gembone's Avatar
Gembone
Gembone is offline
I got to thinking about the engine swap and the oil tube being where it is.
I wonder if they used the tube from the van and the dipstick from the original truck.
Any one know the length difference between the 2?
Old 03-06-2013, 01:20 PM
1986F150six
There is a member whose name is NumberDummy who would definitely know, but he would need to know specifics regarding the two vehicles [your p/u truck and the donor].
I do not know, but would think the dipstick from a van would be longer than one from a pickup truck.
Old 03-07-2013, 10:56 AM
Gembone's Avatar
Gembone
Gembone is offline
Update: I had asked about this in the Bump forum and got a response from ND and this is definitely the wrong dipstick.
Possibly even a GM stick.
Now I am also questioning the tube as most seem to think it sits improperly.
I will see if I can find one at a pick-a-part and try that.
If I have no luck with that I will get a generic one and mark and cut to the length I need.
Thanks for helping.
Old 03-08-2013, 02:37 AM
tiap's Avatar
tiap
tiap is offline
The van dipstick tube is much longer, ends just over the front belts.
Scotty's 52 F3
04-02-2019 12:13 AM
Widetrack455
13
07-10-2014 01:33 PM
Gembone
04-06-2013 08:17 PM
kjhales
03-30-2013 07:10 AM
Quick Reply: diff between SD and HD, also oil capacity.
