ez wiring any good?
ez wiring any good?
Has anyone used EZ Wiring for the harnesses, dashes, and gauges? I found their website and of course it has all of the good things a webpage would have on it. Before I drop around $600 I want to make sure the product is a good product.
18 fuse 21 circuit harness $185
Dash Panel 6 gauge $140
set of 6 Shark gauges $209
Does this seem reasonable? I know in some of the other catalogs the harness is around $400-600.
Thanks for info
Thanks for info
I used the 21 circuit EZ Wire kit for my '59. The instructions aren't the best but not bad. If you have a reasonable understanding of vehicle wiring it won't be too hard to install. All the wires are labeled where they go.
The kit is good for the price but isn't perfect. There are some issues such as the fuel pump wire being hot all the time and the gauges come on when the key is in accessory mode. Just little things like that here but nothing that's hard to fix.
If you have the extra money then one of the higher end kits would definitely be better but I would still recommend the EZ wire kit
