Keep the SD or go to the MAF conversion?
#31
#32
#33
I put a vortech v1 blower on a 351w that only had headers as the other modification. That thing effing produced!!! And there were some here who didn't think a blower like that on an SD system was possible. I am often surprised at what the SD can take for mods, seems pretty flexible in certain aspects.
#34
#35
Let me try a better definition. SD systems rely on known conditions of a given engine, coupled with real-time inputs (RPM, Manifold pressure, TPS) to calculate air-mass and adjust fueling accordingly. MAF systems rely on real-time direct measurement of air-mass (coupled with other real-time inputs) to adjust fueling requirements.
Factory MAF systems can better adapt to changes in an engine's volumetric efficiency (such as when you change a cam) because the incoming air-mass is directly measured. In theory, SD systems have a tougher time with this because the volumetric efficiency of the given engine is "hard-coded" into the calibration file in the PCM (computer).
If using an after-market PCM, or some sort of tuning tool which allows changes to be made to the calibration file, you can throw the above paragraph out the window; it does not apply.
#36
Very informal, couldnt have said it better myself.
But SD is only capable within its certain lifts. Thus, SD friendly cams.
Then you can either find someone to do a custom burn of a preset A/F with proper specs of the cam and timing, or
Go the way of something every tuner in their garage can do and learn from.
This is the Reason behind why I chose the Mustang Computer. Very Easy to the DIY crowd. Rather be able to monitor everything so I can see if it's running right, and can easily plug in my netbook for changes.
#37
#38
The 5.0 HO cam is great for a car. But the torque will not there for a truck.
Regarding the difference between the long and short tube headers. Short tube are easier and less expensive to install. The long tube give a insignificant gain in HP - maybe 2-5 HP depending on the setup. Conanski has a chart that list the different HP gains between short and long tube headers. Word of advice - pay more for a quality headers, this will save you in the long term on installation hassles.
#40
Call comp cam and ask them for a good truck cam and see what they say. I did that, and I was told the stock cam for my truck was good (well...) but they could grind a custom cam for a truck since most of the cams they sell are grinded for cars. When I asked about going from a 1.6 to 1.7 rocker arms they said that is where the custom truck cam would be a be. So I went with the 1.7 ratio roller rockers. I do have 302/5.0 motor so my cam selection might be differnet than a 350 motor.
#42
Sorry, but this is entirely false. There is nothing about Speed Density that ties it to bank-fired fuel injection nor is there anything about Mass-Air that ties it to sequential-fired injection. In fact, you can have Speed Density with sequential injection and you can have Mass-Air with bank injection.
Years ago I was helping a friend with his 5.0 truck that had a cracked head and we picked up some GT40s from the JY and it was a big improvment.
Regards
rikard
#43
#44
Chingo813
09-13-2016 10:32 AM
JB_85F150
06-17-2010 07:16 PM
Leprakrotch
02-27-2005 11:35 AM
