Anyone have a Portapump? - Ford Truck Enthusiasts Forums
Texas Chapter Join Chapter, Leader: LibTimothy
Old 03-05-2013, 06:52 PM
Texas Chain Ring Texas Chain Ring is offline
Texas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to behold
It's some kind of hand pump tool for installing springs. 10 ton I think is what is required. Does anyone have one in Houston?
Thanks.
Old 03-06-2013, 08:09 PM
DRRXR's Avatar
DRRXR DRRXR is offline
DRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputation
Thumbs up
Not me brother. I think I would not mind using one of those tools however I would be tempted to install the hardware compresion bolt on system as a safety measure. Just in case.
Is this what your talking about?
Old 03-06-2013, 11:45 PM
Snuggyworm's Avatar
Snuggyworm Snuggyworm is offline
Snuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to behold
nope, it's a port-a-power. it's something similar, but it's usually hand-pumped, and it's not used to compress the springs. it's used to push the control arms further apart from the frame, so that it creates enough room to slide the new coil springs into the slots.
kinda like reverse engineering. it's like common practice for the 3/4 ton and up vehicles. u dont compress the springs but u make room for them to fit. i'm speculating that this became common practice since the coil springs on the super duties are actually much thicker than the standard coil springs found on 1/2 ton vehicles and below. hence, the compression tools will not be able to grip on the coil springs completely, and tat can be extremely dangerous. damn thing will be like a loaded gun.
Houston Anyone? TexasHighlander Texas Chapter 95 11-27-2014 07:30 AM
Houston Area Diesel Shop or Mechanic? jdbanks Texas Chapter 4 03-02-2011 11:23 AM
Media Blasting Fordication Southwest Region 0 05-30-2008 11:09 PM
Powder Coating Houston Fordication Texas Chapter 1 02-12-2007 09:26 PM
Sandblasting in Houston lzna50 Texas Chapter 1 10-30-2003 08:34 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
