Update on oil sample
This is my latest report with almost 4k miles , I am thinking this will be my threshold for oil changes right at 4000 miles unless something else changes,
GORDON: There were some slight improvements in aluminum and iron in this sample compared to last
time, and chrome is a little lower too. Improvements are always nice to see, but they're especially nice when
the oil change interval is longer. This engine is making less metal now than it was. No contamination was
found, and the used oil itself was in great shape. We like this interval for you since your engine tends to
make a little more metal than most. We're guessing it probably works a little harder than other engines
though, and that's okay. Nice report!
MI/HR on Oil
3,961
3,283
2,229
1,808
UNIVERSAL
AVERAGES
MI/HR on Unit
105,603
UNIT
101,641
93,141
91,012
Sample Date
12/26/13
LOCATION
AVERAGES
10/04/13
04/03/13
02/09/13
Make Up Oil Added
0 qts
0 qts
0 qts
0 qts
ALUMINUM
16
17
19
15
CHROMIUM
IRON
24
26
32
16
32
30
COPPER
LEAD
TIN
MOLYBDENUM
NICKEL
MANGANESE
SILVER
TITANIUM
POTASSIUM
BORON
15
17
20
25
SILICON
SODIUM
CALCIUM
2276
2455
2471
2635
2438
1731
MAGNESIUM
385
PHOSPHORUS
952
1042
1074
1055
1085
993
ZINC
1007
1176
1233
1241
1221
1151
BARIUM
16
15
Values
Should Be*
SUS Viscosity @ 210°F
66.1
65-75
74.5
68.6
73.0
cSt Viscosity @ 100°C
11.90
11.6-14.5
14.13
12.59
13.75
Flashpoint in °F
420
>410
465
410
420
Fuel %
<0.5
<2.0
<0.5
TR
<0.5
Antifreeze %
0.0
0.0
0.0
Water %
0.0
0.0
0.0
0.0
0.0
Insolubles %
0.3
<0.7
0.3
0.1
0.3
TBN
TAN
ISO Code
PROPERTIES ELEMENTS IN PARTS PER MILLION COMMENTS CLIENT UNIT
MI/HR on Oil
3,961
3,283
2,229
1,808
UNIVERSAL
AVERAGES
MI/HR on Unit
105,603
UNIT
101,641
93,141
91,012
Sample Date
12/26/13
LOCATION
AVERAGES
10/04/13
04/03/13
02/09/13
Make Up Oil Added
0 qts
0 qts
0 qts
0 qts
ALUMINUM
16
17
19
15
CHROMIUM
IRON
24
26
32
16
32
30
COPPER
LEAD
TIN
MOLYBDENUM
NICKEL
MANGANESE
SILVER
TITANIUM
POTASSIUM
BORON
15
17
20
25
SILICON
SODIUM
CALCIUM
2276
2455
2471
2635
2438
1731
MAGNESIUM
385
PHOSPHORUS
952
1042
1074
1055
1085
993
ZINC
1007
1176
1233
1241
1221
1151
BARIUM
16
15
Values
Should Be*
66.1
65-75
74.5
68.6
73.0
11.90
11.6-14.5
14.13
12.59
13.75
Flashpoint in °F
420
>410
465
410
420
Fuel %
<0.5
<2.0
<0.5
TR
<0.5
Antifreeze %
0.0
0.0
0.0
Water %
0.0
0.0
0.0
0.0
0.0
Insolubles %
0.3
<0.7
0.3
0.1
0.3
TBN
TAN
ISO Code
Great writeups, really interesting to read this. I believe this is a way of understanding YOUR engine and whats best for it. I also think that it allows others to see what they can expect(oil change interval) for whats considered average and what not. I bet they can help you detect an early failure as well, like if a piston is crumbling, etc.
Spudman2005
6.7L Power Stroke Diesel
17
06-26-2019 10:12 PM
CKetchum
6.4L Power Stroke Diesel
08-10-2013 01:01 PM
jtharvey
05-02-2006 01:56 PM
