PCM fuse is clicking - Ford Truck Enthusiasts Forums
Old 03-05-2013, 04:43 PM
Gonu50 Gonu50 is offline
Gonu50 is starting off with a positive reputation.
I have a 2000 F150 2wd with a 5.4 engine. I am helping a friend with it. The truck had not run for 18 months. The original issue was fuel supply. I changed the fuel pump yesterday and it started right up.
I picked it up this morning and it made the ride home with a couple of stops with no issues. I drove it to the store this afternoon and when I got back in to leave, it would not start. I heard a clicking from the interior fuse panel and it was the PCM fuse. I was trying to remove it and it stopped clicking. The truck started and I drove it home. Once home, I started it several times without an issue.
So, I went to leave again and it would not start. Th PCM fuse started clicking and the theft warning light started flashing. What is up?
Old 03-05-2013, 08:57 PM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is offline
enriched&beyound is starting off with a positive reputation.
try changing the relay to the ECM or as you put it the PCM. & for the fuel pump.
see if there is another set of keys for it...try the other set and see if the theft light still flashes.
also could not hurt to make sure all the battery connections are good seeing that this sat for a extended period.
Make sure the battery is good and that the Alternator is charging properly.
if it doesn't behave better after that...then most likely there is a issue with the PATS system.
Old 03-06-2013, 06:33 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
I've never seen or heard a fuse "click"...
Old 03-06-2013, 07:01 AM
Good point. I Guess the correct description should have been a relay (black cube) in the interior fuse box.
Thanks!
Old 03-08-2013, 10:22 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
There are 5 relay positions, which one was cycling?
None of them should have anything to do with starting but only a secondary reaction. Check owner book page 209.
There are several fuses dealing with the PCM on that panel..
Sounds like a fuse seating issue or a panel issue.
The PATS lamp flashing might possibly tell you a trouble code that could be helpfull.
When it flashes there will be a no start.
Let it set for a few minutes in 'run' to see if it detects a trouble code.
Good luck.
Old 03-09-2013, 11:07 AM
Thanks for the ideas Bluegrass 7! This occurred on Wednesday. I charged the battery and drove it to Autozone on Thursday. The alternator is working fine. I have not had any other problems since, though I am still staying close to home on m trips. I guess it was another "been sitting for 18 months" glitch.
No Start After PCM Removal mahause 1999 - 2003 7.3L Power Stroke Diesel 25 04-21-2012 01:35 AM
96 F-250 HEAVY DUTY - keeps cutting off and blowing pcm fuse CRAZYC123 1987 - 1996 F150 & Larger F-Series Trucks 7 08-26-2011 11:02 PM
Clicking sound under the hood when engine turns off on 08 Expedition Packing4Protection 2007 - 2014 Expedition & Navigator 0 12-27-2010 07:22 PM
96 F150,cranks over,no fire, no fuel Trublufords 1987 - 1996 F150 & Larger F-Series Trucks 6 01-13-2009 07:27 AM
No responce from PCM fridgeddiesel 1994.5 - 1997 7.3L Power Stroke Diesel 11 12-11-2005 11:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
