Econoline dip stick
Old 02-08-2013, 04:42 PM
kjhales's Avatar
kjhales
kjhales is offline
Econoline dip stick
How can I tell if I have the correct dip stick? I recently bought a 1965 Econoline with the 240 ci engine. I found a lively discussion thread from a couple of years ago regarding oil capacity of the L6 engines, and concluded that with an oil change I'd need at least 5 qts. and likely a little more. It turns out that with 5 qts (and filter change), the dip stick shows it to be WAY over-filled. I drained about a quart out to get it down to "full". So, either there is 2 inches of crud in my oil pan, or I have the wrong stick, or ......what? The dip stick in the van is about 13 3/4 inches long (measuring from where the top of the tube rests), with the full mark about 1 5/16 inches from the tip. No part numbers on the stick. Can anyone confirm this is what the stick is supposed to be, or suggest why 5 qts over-filled the oil pan? Thanks. kjhales
Old 02-17-2013, 06:07 PM
EmilBarnabas's Avatar
EmilBarnabas
EmilBarnabas is offline
There are different sticks for different vehicles. Some sticks go into the pan and some go into the block. Some tubes are longer than others.
Fill the engine with the right amount of oil. Run it a while to get the oil in the filter, then shut it off and check the level. Make a mark on your dipstick. That's the new full level.
Old 02-19-2013, 11:40 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C5TZ-6750-J .. Engine Oil Dipstick / 12.52" top of shield to fill / 13.06" top of shield to add / 13.82" top of shield to end / Available from Ford.
Applications: 1965/66 F100/250 240/300 I-6 4WD & F350 / 1965/67 Econoline 240 I-6 / 1965/72 F600 300 H/D I-6.
MSRP: $15.22 // FTE sponsor tousleyfordparts.com price: $10.04.
Old 03-25-2013, 09:05 PM
kjhales's Avatar
kjhales
kjhales is offline
Thanks, NumberDummy. My measurements were less than 0.1 inch off from what you listed, so I will assume it's telling me the truth.
Old 03-30-2013, 07:10 AM
NumberDummy
Seems I already answered this question.
Gembone
22
10-02-2017 12:25 PM
Widetrack455
13
07-10-2014 01:33 PM
Baxtjh
03-12-2010 05:20 AM
millerdog
01-18-2010 09:55 PM
Ken Blythen
09-28-2008 02:20 AM
Quick Reply: Econoline dip stick
