pulsating brake pedal - Ford Truck Enthusiasts Forums
Old 03-05-2013, 09:06 AM
mikren mikren is offline
mikren is starting off with a positive reputation.
when braking i would feel the pedal pulsating...figured the pads were finished. checked them out and they were not in that great a shape so i changed them all around. I'm still getting a pulsating feeling in the brake pedal....u guys think i just need to bleed them or are the discs warn or warped or something ? thanks
mike
Old 03-05-2013, 10:17 AM
shooter123 shooter123 is offline
shooter123 is gaining momentum as a positive member of FTE.
warped rotors. have them turned or replace them.
Old 03-05-2013, 11:54 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.
New rotors and pad do wonders for brake feel.
The hint of the day is 'do not' over tighten the front discs.
It can put a wavey distortion in them that will be temperature sensitive and drive you nuts wondering what's going on, at different times.
If left like that long enough , the discs won't recover from a wear pattern by retorqueing.
Good luck.
Old 03-05-2013, 11:58 AM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
Probably a stuck piston in the caliper also. Everything U ever heard bad about disc brakes is started with sticky caliper pistons. These are usually brought about by a hole to the boot seal. When U got a truck 10 years old, 100,000 miles, save UR selves a lot of grief.
Old 03-05-2013, 12:41 PM
ok thanks.... how could one over tighten front discs ??? do you mean caliper ? or am i not getting something ?
Old 03-05-2013, 12:57 PM
RebColonel RebColonel is offline
RebColonel is starting off with a positive reputation.
He means over torqueing the wheel lug bolts. If your brake pedal is pulsating do what Shooter said and turn or replace the rotors.
Old 03-05-2013, 02:18 PM
thanks , will do. yeah lug nuts are to specs. Thanks again
Old 03-06-2013, 03:08 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
HI Mike, we have some great prices on rotors if you need them. Here's a link to them on our website if you want to see what we have. Tony
F150 Brake Rotors
Old 03-07-2013, 07:08 AM
R Pope R Pope is offline
R Pope is starting off with a positive reputation.
I broke two studs off getting a tire off my truck, with the spare on I had a bad vibe getting to town to get a few new studs. Went away when i replaced them.
BTW. the pricing on studs is variable. Ford sold me the only one in stock for 6 bucks, the Parts Source store nailed me for 23 fun tickets! WTF?
Brake pedal is pulsating bad hard to turn wheels retired8282 1999 - 2003 7.3L Power Stroke Diesel 12 02-05-2017 10:52 AM
Can't catch a brake F35ott 1999 to 2016 Super Duty 15 01-01-2017 10:26 AM
ABS not pulsating? frdbronco8 1999 to 2016 Super Duty 1 08-28-2016 07:41 AM
Super Duty brakes pulsating jjc103 1999 to 2016 Super Duty 8 01-07-2014 02:47 PM
2006 f350 brake Woes fairlane70 1999 to 2016 Super Duty 6 08-10-2013 06:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
