Power Steering fluid change - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 03-05-2013, 09:44 AM
KennyG228 KennyG228 is offline
KennyG228 is starting off with a positive reputation.
Greetings!
I am one of the folks who got in on the Red Head group buy and I am now planning my work. I want to change the power steeing fluid and I saw some of the threads on how to do it. My question is should I flush the fluid before or after I change the box? If I do it before, it seems to be a waste of fluid. After, it seems that some of the old fluid will still be in the system. My Ex has 183,000 miles on it. Any suggfestions would be most appreciated.
Old 03-05-2013, 11:01 AM
rcboats1's Avatar
rcboats1 rcboats1 is offline
rcboats1 is gaining momentum as a positive member of FTE.
Do it before. What you call wasted fluid I call insurance.
Let us know how you like the change to the Red Head, I am thinking that I need to do it soon.
Old 03-05-2013, 11:10 AM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
It's not going to matter.
Old 03-05-2013, 11:53 AM
timf150's Avatar
timf150 timf150 is offline
timf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud of
You can go either direction but I did it in this order.
1. Changed the fluid.
2. Go for test drive to make sure all is good
3. Install the RedHead
4. Top off fluid after the change.
5. Turn on vehicle and move steering left to right and check fluids.
6. Take test drive and check fluids - it may be noisy for a bit but should go away if fluids are good
You will not loose that much fluid when you change out the steering pump but it will require more.
Tim M
Old 03-05-2013, 12:08 PM
You're only talking 75+- cents loss in fluid. I thought I was frugal.
Old 03-05-2013, 12:23 PM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
If I were installing a ~$400.00 steering box, I would put serious thought to changing that 45.00 pump and relatively cheap fluid anyway, and flushing the PS cooler. just my 2c.
Old 03-05-2013, 04:32 PM
Thanks for the feedback. No, I am not frugal, I am cheap but I do want the best for my baby. I priced a box at my local Auto Zone and it is $60.00 with resevoir, $45.00 without. Since my box is due tommorow (yes I called early yesterday), I will order a new box tonight and do it all tomorrow. I am excited to get it done!
Old 03-09-2013, 09:18 PM
Restlesswildman Restlesswildman is offline
Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.
Flush system before the swap. Change all the parts out and top off the system.
You could pull the return line and run the engine and drain the system before swapping the parts out.
Whatever MAKE SURE you do flush the cooler!
Old 03-10-2013, 08:43 AM
Patriotic Rottweiler's Avatar
Patriotic Rottweiler Patriotic Rottweiler is offline
Patriotic Rottweiler has a very good reputation on FTE.Patriotic Rottweiler has a very good reputation on FTE.Patriotic Rottweiler has a very good reputation on FTE.Patriotic Rottweiler has a very good reputation on FTE.
More cheap insurance... Install the Magnefine 3/8" filter R038M-P. I got 4 of them from eBay for about $12 each. I plan on changing them every year.
Old 03-10-2013, 03:17 PM
Thanks for the feedback folks. I swapped out the pump and the box, then I filled and flushed the system with some mercon v. after everything was clean, I added an in line filter from autozone. Everything is now squeaky clean.
power steering fluid or trans. fluid abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 4 04-16-2013 06:36 PM
another power steering fluid question (long) mark4000 Ranger & B-Series 5 07-29-2011 08:09 PM
change brake fluid 79 f-150 monster79f150 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-29-2011 01:44 AM
Best way to flush tranny at home? ___ Aerostar 7 03-25-2007 02:21 PM
92 Ford Aerostar (A4ld trans) 3.0 leaking trans fluid when driving 1+ hours cnajp Aerostar 23 09-21-2005 11:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
