Rear Dana 60 Wheel Bearing Adj' Nuts...
Old 03-05-2013, 01:58 AM
robertbruce's Avatar
robertbruce
robertbruce is offline
i;ve had a search for these and all i can find is nuts for the front...
The rear nuts are very different from the front ones...
does anyone know where i can get them from?
Old 03-05-2013, 07:29 AM
robertbruce
"spindle nut" - that is its proper name
options so far
...plenty for front - not an option
...plenty with plastic insert, not suitable
...plenty for later model, ratchet style
only two references on ebay, no pics
have mailed them
next is spicer corp
Old 03-05-2013, 07:32 AM
robertbruce
Plan B, use ratchet style on LHS, use oldstyle on RHS...
Old 03-05-2013, 03:24 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by robertbruce
I've had a search for these and all i can find is nuts for the front.
Spindle nut is not what FoMoCo refers to them as.
There are TWO different types of these Rear Wheel Bearing Nuts. One is Dana 60 only thru 1968. The other is Dana 70 & 1969 and later Dana 60.
Lock washers are also required (should not use the old ones over again). Its tabs are designed to be folded over onto the sides of the hex nuts to secure them in place.
61-4252 .. Rear Wheel Bearing Nut-Dana 60 only / 1 13/16" thread - 2.38" Hex / Obsolete
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
KLIMESH MOTOR SALES in Calmar IA has 3 = 563-562-3241.
MANDERBACH FORD in Temple PA has 5 = 610-929-3659.
B6Y-4252-A .. Rear Wheel Bearing Nut / 2" -16 x 2.56" Hex / Obsolete
NOS PARTS LTD in Waxahachie TX has 5 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 50 = 513-731-3304.
61-1124 .. Lock Washer-Use with 61-4252 nut / 2 3/4" O.D. x 1 27/32" I.D. / Obsolete
FRIESEN FORD in Aurora NE has 4 = 402-694-3111.
NOS ONLY in San JOSE CA has 4 = Only number listed is 800-667-6659 (toll free-won't work from 'down under').
I called, left a message, asked for their regular number. Will edit it in when I hear back.
B6Y-1124-A .. Lock Washer-Use with B6Y-4252-A / 2 5/16" O.D. x 2 1/32" I.D. / Obsolete
GREEN SALES CO. has 49.
Green Sales (greensalescompany.com) ships "across the pond" via Fed-Ex. I dunno if the others will.
Old 03-05-2013, 04:22 PM
robertbruce
a HUGE thanks Bill...
i thought there was only two sizes...
there must have been millions of these nuts around at one time but now they seem a little rare...
i wonder what people have been using this side of the pond...
nogig
08-08-2019 07:21 AM
jakeharp
11-10-2017 01:28 PM
aj3501
03-31-2014 07:04 PM
kmorgancraw
03-01-2013 07:48 PM
dougbrown
16
10-04-2010 09:55 PM
Quick Reply: Rear Dana 60 Wheel Bearing Adj' Nuts...
