My 1989 F150 - Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
My 1989 F150
Old 03-04-2013, 09:25 PM
Krisverde Krisverde is offline
Krisverde is gaining momentum as a positive member of FTE.Krisverde is gaining momentum as a positive member of FTE.
My 1989 F150
So I've inherited my grandpa's truck that he bought brand new in 89 from Pasco, WA.
My goal is to make it look new again with some engine/suspension mods. Truck has a 5.0 with 129k on it. AOD has been rebuilt already. Interior isn't too bad on the truck. Carpet needs a little cleaning from the people who have had it for the last couple years. Dash is crack free.
I've got a few things to deal with to make it road worthy again. Right now I need to redo the brakes. After that I need to deal with 2 broken bolts on the top of the waterpump. Once that's dealt with ill start with exhaust and continue from there. I definitely want to do a maf conversion.
Also none of the power windows work. I think the passenger side motor is seized and the regulator or the bushings in the motor failed on the driver side.
List of stuff I want to get done (not in any particular order):
Long tube headers
Delete smog stuff (i've passed in az without this stuff before)
Heads
Roller assembly stuff for the engine.
HO cam
Maf conversion
Valve body with OD lock out from silverfoxtrans
Deep pan for AOD
Haven't decided if I will level the truck out or do a 3/4 drop
Might do some sort of Forced Induction either turbo or supercharger.
Anyways here are some pics.
I put a blanket over the seat so the small rip wouldn't get any bigger and I am half tejano LOL.
Sweet curtains right?
It's weird owning something that has so much history in my family.
Like I said I want to make it look new again because my grandpa always talked about getting repainted since the paint went to hell when he moved to AZ
Old 03-07-2013, 08:43 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is offline
Redneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputation
First off glad you got the tittle thing organized out. Also wanted to subscribe because I like hearing on these projects. Hope the 302 treats you well.
Trav
Old 03-07-2013, 09:36 PM
Thanks man. It was actually extremely simple. Everything worked in my favor.
Old 07-16-2013, 03:23 AM
Ill have to update this. I ended up pulling heads an all that fun stuff. THink I am going to end up pulling engine so I can reseal it on a stand. Engine looks simple to pull.
Old 07-18-2013, 01:20 PM
It is pretty simple to pull harderst part like usual is the exhaust.
Trav
Old 03-10-2014, 05:30 PM
Haven't really posted much on this truck lately. Decided to ditch the 302 as I picked up an f4te 351 with 90k on it. Stripped it down to short block. Ill probably just clean the block up and put a set of tfs heads on it.
Old 01-12-2015, 02:43 PM
Update:
Finally got the 351 in and running have some running issues but at least the engine is finally in lol.
Clocking the rack The Outlaw 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 04-14-2016 03:47 PM
1963 "Wrong bed" Build Thread davewave649 1961 - 1966 F-100 & Larger F-Series Trucks 22 01-18-2015 01:25 PM
Weird light I found underneath the bed of my truck...who else has it? Krisverde 1987 - 1996 F150 & Larger F-Series Trucks 5 10-21-2013 12:23 AM
Let's see your Superduty caves!! Big-Sarge 6.7L Power Stroke Diesel 40 02-05-2012 11:55 AM
Seat Swap mudder460 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-17-2009 05:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
