2002 F-150 Rear End Swap Question - Ford Truck Enthusiasts Forums
Old 03-04-2013, 07:18 PM
PStruwing's Avatar
PStruwing PStruwing is offline
PStruwing is gaining momentum as a positive member of FTE.
Hello all
I need to get my 2002 F150 XL out of my driveway but has the famous blown up 8.8 rear end.
Can I by a 97 to 99 drum brake truck and swap the disks from the blown axle and put the earlier rear in the 2002?
Old 03-05-2013, 12:27 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
You can't swap disc to drum or drum to disc between the units.
You know one uses calipers and the other uses backing plates and shoes.
A problem is, you mix non stock system parts like this and your brake bias/balance between front and rear goes out the window.
Said another way, line pressure to the rear brakes is different between the two types as controlled by a pressure regulator at the master cylinder.
For example if the rear gets to much pressure, they lock up before the fronts do their share and vic vesa.
Then there's ABS to have an issue with from any imbalance.
The 8.8 has been around since the mid 80s and still being used.
I wouldn't say it's famous for any issue used in a stock application for which it is meant.
Go putting big tires on and running through the woods, it might give a problem at times.
Repair what you have if it is only the internals and be done with it and the hassle.
Good luck.
Old 03-05-2013, 08:32 AM
Spotty Spotty is offline
Spotty is gaining momentum as a positive member of FTE.
What is blown up? I have rebuilt a couple 8.8's I have owned....not very complex.
Old 03-05-2013, 05:23 PM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
Good luck.
I think the OP is asking if he can buy a drum brake rear end and swap the disk setup from his original rear end onto it, thereby maintaining the stock braking setup.
2002 crown vic rear end into f150 86f150lariat 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 10-18-2014 08:28 PM
2002 F-150 XL Rear Brake Line Question PStruwing 1997 - 2003 F150 2 06-24-2012 07:13 AM
2002 F-150XL Rear End Blown Up Axle Code 27 PStruwing 1997 - 2003 F150 4 12-11-2011 01:27 PM
sport trac 2010 rear end on 2002 f150 hollenjoe Clutch, Transmission, Differential, Axle & Transfer Case 0 09-24-2011 03:41 PM
rear axle trouble Blueovalguy88 1987 - 1996 F150 & Larger F-Series Trucks 19 03-05-2006 01:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
