The head gasket must have been put on wrong. Oil turns milky when water gets in the oil, usually from a blown head gasket, warped heads, or even a cracked block.
If you don't drive your truck a whole lot, and/or take it for short trips, the valve covers will be coated with milky, foamy oil. Any vehicle will do it, old or new. The fact that it's coming out the PCV vent isn't normal, though. PCV valve could be clogged up.
Agree it is likely condensation. Crankcase vapor has moisture. If the oil in the sump was milky I'd be more worried.
Check PCV system and seal on the vent then take it for a good drive and warm it up. Also check for correct T stat as that will help keep engine temps where they need to be.
X2! Check the complete PCV system. Crap... Blue and White typed everything I was gonna say. I've seen this issue many times. This issue has fooled several people to think worse things were wrong as well.
Easiest way to tell if it's your head gasket. Take your radiator cap off and look at your fluid. If it's lower then where it oringially was then it's a head gasket. If it's the same probably just condinsation.
