Need help - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Need help
Old 03-04-2013, 05:20 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Need help
Anyone got a spare alternator I can borrow while I source a new one from the States.
Old 03-05-2013, 02:04 AM
wallsy's Avatar
wallsy wallsy is offline
wallsy is starting off with a positive reputation.
Wish I had a spare I could give you mate, but I don't unfortunately. Sorry.
Old 03-05-2013, 05:10 AM
aussie_f350's Avatar
aussie_f350 aussie_f350 is offline
aussie_f350 has a good reputation on FTE.aussie_f350 has a good reputation on FTE.
yeah mate, pm me your address i get it out tomoro, bit different than a stock one tho???
Old 03-05-2013, 05:13 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
Brian, is it worth getting the local auto-electrician to see if he can squeeze some more life out of it while you're waiting for a replacement to arrive from the US?
Otherwise, on the battery charger every night and avoid night time driving till the new one restores normality.
Old 03-05-2013, 07:07 AM
Nah. had mine checked and its fried. Run it for 30 seconds on its to hot to touch. $449 for a new one. What a wanka. Just couldnt wait so i found one on ebay (200amp) for 170 USD + 45USD for shipping. Thanks for the offers boys. Good to see FTE to the rescue.
Old 03-06-2013, 12:26 AM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
On the alternator front,
Is it hot after sitting for a while as well? (usually a shorted diode)
Have you done an output test? (it is usually the regulator that dies, not the alternator)
Old 03-06-2013, 04:35 AM
took it to a sparkie and he tested it. Not worth getting it fixed here cause for less I can get a 200amp. I run a third battery in the rear for camping so the extra GG's will help.
Old 03-06-2013, 09:28 PM
Yeah, that's usually the way. Are you getting the Ambo unit, or an aftermarket one?
Old 03-07-2013, 01:32 AM
Old 03-07-2013, 03:37 AM
Looks like a replica of the ambo alternator, very good unit, and has an external regulator so if it fails, rebuilding it is much cheaper. When I worked at FoMoCo, the parts price for a genuine unit was $6k...
Old 03-07-2013, 04:36 AM
Nice one Brian - flea-bay to the rescue!
Old 03-07-2013, 05:16 AM
Quote:
U have to be kidding ???
Old 03-07-2013, 06:11 AM
That must be $6k with engine attached, maybe?
It'd be cheaper to fly to the US, buy one at AutoCo, and fly back - 1st class!
Not exactly going to attract any 'word of mouth' customers is it!
Old 03-07-2013, 05:50 PM
Diesel Submariner's Avatar
Diesel Submariner Diesel Submariner is offline
Diesel Submariner is gaining momentum as a positive member of FTE.
$$$Alt
G'day Fellas,
I ran into a bloke with a F-Truck in Strathalbyn SA a couple of years ago on his full time on the road haulin' a 5th Wheeler.
He was down in the mouth and in shock recovery from paying $4.5K for an alternator through a Ford Stealership somewhere in NSW .
Poor bugger.
I was at Rapid Bay in SA a couple of weeks ago and another bloke was doin' the same thing full time on the road with a 5th Wheeler and using Ford Stealerships around the country to do his servicing and repairs at a shocking cost.
His missus was getting pissed with the expense and this is where these trucks get a bad rep as too bloody expensive when operated by the poor buggers with no mechanical background or aptitude and only go to Dealerships.
Gotta feel sorry for the poor buggers. But when you try to set them straight you may as well be talking left handed Swahili.
Cheers,
Reg
Old 03-07-2013, 09:15 PM
Quote:
I wish I was.
Back in 2004 a set of injectors for the 7.3 also cost ~32k IIRC (yes, you could actually buy a full engine with turbo through the parts system cheaper)
I was able to get the cost down on the injectors, but not the alternator.
If you ever have to get parts for your 7.3 from a dealer here (either because its a specific item to Brazilian built units, or because you are in a rush), make sure they contact Ford Australia to clarify/contest the price and rattle the chain, low volume parts can often be priced excessively high by the dealer and by Ford, and despite what you may think/be told, there IS wiggle room, and sometimes quite a lot. (I think the injectors we got down to about 8k for a set, not great - but could you imagine being hit with a 32k bill on parts alone for replacing injectors!)
10 years! jseim44 Nebraska Chapter 8 04-29-2014 09:07 AM
Where is serial # on 1946 or 47 half ton pick up? Trulyvintage 1947 and Older Ford Trucks 3 05-20-2011 11:40 AM
I need HiSPL Testing..... 3 08-19-2009 06:52 PM
Spelling Lesson 1; "I before E" shorebird General NON-Automotive Conversation 13 08-07-2009 09:55 PM
I like my torque.....do i sacrifice it when I .... Ford_Six 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 11-09-2002 09:56 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
