1954 Radiator - Ford Truck Enthusiasts Forums
1954 Radiator
Old 03-04-2013, 08:15 AM
1954_NJ_F100's Avatar
1954_NJ_F100 1954_NJ_F100 is offline
1954_NJ_F100 is starting off with a positive reputation.
1954 Radiator
I am looking to pick up an original 1954 radiator. Does anyone know if there were different size radiators for 1954 F-100's?
Thank you.
Old 03-04-2013, 12:55 PM
teardropty's Avatar
teardropty teardropty is offline
teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.
Do you have a 6 cyl. or 8? They are different. Personally unless you are going for authenticity, swap over to a newer Dodge radiator. I picked up a new radiator that required very little mod for $110 at Autozone. Anything original is prone to corrosion and failure and anything recored is big bucks $$$. Good luck.
Old 03-04-2013, 03:38 PM
abe's Avatar
abe abe is offline
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
Quote:
can you tell me what year Dodge, car or truck, etc/ I want to look into this.
thanks, Abe
Old 03-04-2013, 06:11 PM
I have a 239 V-8 & was looking for an authentic look. Is there a way to tell what size raditor to look for? i.e. - numbers or size?
Thanks
Old 03-04-2013, 06:18 PM
DR Smith's Avatar
DR Smith DR Smith is offline
DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.
If your 239 is a overhead V8.I have one that has been recored.And will sell cheap as I have replaced it with a aluminum one.
Old 03-04-2013, 06:31 PM
teardropty's Avatar
Quote:
thanks, Abe
Hey Abe,
Not sure what motor you have but here is the FTE link I used when I did my last build. I won't try to explain it all, just refer you to the best of FTE
http://www.ford-trucks.com/forums/11...ce-needed.html
Old 03-07-2013, 09:10 PM
Quote:
I am interested in your radiator...I tried sending a private message. Will try again.
What is a Deluxe model for a 1954 F100 Mlacelle 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-21-2015 11:15 PM
1954 F100 Heater Box medicpg 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 12-04-2014 12:31 PM
Seat belts for 1954 F100 medicpg 1948 - 1956 F1, F100 & Larger F-Series Trucks 47 08-11-2014 07:04 AM
Tires for 1954 F100 1954_NJ_F100 WTB - Ford Trucks & other vehicles 0 08-04-2014 06:49 AM
Chassis swap our1954 1948 - 1956 F1, F100 & Larger F-Series Trucks 43 07-26-2014 06:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
