Motor Madness
Old 10-23-2017, 08:41 AM
rock2610d's Avatar
rock2610d
rock2610d is offline
Motor Madness
So I am looking at planning my next Excursion motor.
Question 1) what is an AOD Ford transmission?
Question 2) is the 4r100 an AOD?
I have found adapters to fit a 460 to E40d and AOD transmissions. But nothing on 4r100s specifically.
I don't really know where to post this question.....engines, transmissions ? So I posted here.
Any help would be appriciated.
My reason:
I have a custom built 552 cid 460 motor with cobra jet heads looking for a home.
Old 10-23-2017, 01:28 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
AOD = Automatic Over Drive
4r100 is AOD
Not all AOD transmissions have the same bell housing. The E40 is used in the expedition and my GUESS is that it has the same bellhousing as the 5.4 Excursion with the 4r100
If you are going hybrid drivetrain I'd ditch the 4r100 and consider a 4L80e as they have plenty of aftermarket support for swaps.
Old 10-23-2017, 02:06 PM
rock2610d's Avatar
rock2610d
Was really wanting to keep 4r100 because I'm going to use the ford excursion 5.4 pcm to operate the 552 motor and transmission.
Using a cps adapter, and crank position switch I can just plug and play.....I hope.
If I can adapt the 460 configuration to the 4r100.
Lowdwn
06-09-2018 06:00 PM
F100Gasser
05-03-2017 06:49 PM
vee10td
08-15-2011 10:34 AM
metalmilitia
18
07-10-2008 09:03 PM
lucas restoration
12-11-2003 10:53 PM
Quick Reply: Motor Madness
