Custom Ford Patrol - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Custom Ford Patrol
Old 03-03-2013, 08:56 PM
Madriver911 Madriver911 is offline
Madriver911 is starting off with a positive reputation.
Custom Ford Patrol
Hi my name is Trevor and i'm building a one of a kind Nissan Patrol. Its a 1975 G60 medium wheel base (100") patrol that is under going a full rebirth. It will be housing a 1996 7.3l Powerstroke V8 mated to a zf6 and a atlas 4 speed.
Hope you guys like it
putting this
into this
TRev
Old 03-04-2013, 04:34 AM
Diesel Submariner's Avatar
Diesel Submariner Diesel Submariner is offline
Diesel Submariner is gaining momentum as a positive member of FTE.
7.3 Pootrol
G'day Trev,
You might want to check out a fella on this forum trying to stuff a 7.3 into a Tojo in Sth Africa.
That era Pootrol had a serious issue with the Chassis buckling and breaking in two .
Finding the space and allowing for the weight of a 7.3 + a ZF would be an interesting exercise.
All I can say is good luck mate and keep a good running blow by blow thread on this as you will have an audience willing you on.
Cheers,
Reg
Old 03-04-2013, 04:48 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
There was another thread somewhere where a US Navy guy stuffed the 7.3 into his International Scout. He solved the under-power issue but created a whole pile more (which be also solved).
Old 03-04-2013, 06:09 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Not bad for ya first post. Welcome to FTE bro.
Im with Reg on this one. A 500kg motor in the front of that. WOW.
Old 03-04-2013, 08:22 AM
Quote:
Originally Posted by Diesel Submariner View Post
G'day Trev,
Cheers,
Reg
Quote:
Thanks guys for the feed back and I'll do a search for those projects.
I'll give you some more info about the project. The driveline will weigh 150kg more then the original but i'll be doubling the cubes, doubling the transmission gears and doubling the transfer case gears. The chassis rails are a box section and the seem very strong but i will be adding fish plates and other bracing especial over the coil seats.
I'll be trying to minimize the weight by running a dry sump system, chromoly tubing for the cage and roof rack, alloy wheels and any other thing i can save weight on.
I know I'll be expecting issues but with the knowledge of the mechanical fitters at work, the forums I'm on and the tools I've got, I should be able to solve every issue.
Here's some of the tools I own
Question:
How do these engines and computers go by running without a turbo?
Thanks
TRev
Old 03-04-2013, 05:19 PM
y no turbo ?
Old 03-06-2013, 08:58 AM
I would like to remove the turbo for a couple of reasons. One, I'm not a fan of turbos and I'm trying to build a very reliable vehicle for remote self sufficient traveling. Two, I'm running out of room in the engine bay. The engine will be very close
to the firewall so I don't have much room for the exhaust system. I'm also running out of height which is one of the reasons I'm going to run a dry sump systems and I'm also running out of grill space for cooling. Running engine radiator, transmission cooler, oil cooler, condenser and thermo fan, there Isn't much room for an inter cooler.
TRev
Old 03-06-2013, 08:20 PM
aussie_f350's Avatar
aussie_f350 aussie_f350 is offline
aussie_f350 has a good reputation on FTE.aussie_f350 has a good reputation on FTE.
So will you still run electronic injection? Will make the tuning interesting, factory ECM or aftermarket?
Old 03-07-2013, 01:42 AM
Yes endeed Andy. I understand where you are coming from but running a turbo'd motor without one would make it pretty gutless. I not to sure how you would tune around that.
Trevor - you may be best to ask that question here m8
http://www.ford-trucks.com/forums/forum170/
'48 F1 Resto-Mod 48_F1 Projects 68 12-24-2016 12:44 PM
My 78 F250 Resto so far Tom French 1973 - 1979 F-100 & Larger F-Series Trucks 20 04-14-2013 11:24 PM
is this a true set of 1979 hp dana 60 axels. 71hightoy 1973 - 1979 F-100 & Larger F-Series Trucks 17 11-24-2009 02:01 AM
Pics of my truck with a couple questions!! rich gill 1987 - 1996 F150 & Larger F-Series Trucks 21 07-04-2009 11:52 PM
newbie pics silver&green94 Aerostar 13 02-08-2009 04:01 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
