i have a 2000 excursion with the 7.3 in it. when i turn the key it wont crank over but i can jump the sylinoid and it will fire right up. i replaced the sylinoid and i dont know what else it could be
Neutral switch is part of the PRNDL switch . Mounted on transmisson , driver side behind shift linkage where cable attaches . You might have a bad switch or wiring . Here is where a wiring diagram would help . It could be wiring , relay , Igniton switch ect.
Funny , I know . But the reason I said that is it could be something strange . I just worked on a 98 ranger that would not turn off .Igniton switch disconnected , truck still ran . The friggin headlight switch was bad , backfeeding to the dash and GEM .keeping the ecm powerd up ! No wiring issues , internal switch problem .Go figure . Ain't seen that before . Tell that one to your buddies . They won't beleive it either .
When I started my truck this morning it was hard to put it in to reverse. Could that be because the PRNDL switch is bad
Could be mechanical , not likley the switch . Did not read where you are , Ice build up can cause issues like you describe . Parked on a grade with parking pawl loaded , ect .
