2007 Expedition Shudder issue - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 03-03-2013, 02:31 PM
becraftj1276 becraftj1276 is offline
becraftj1276 is starting off with a positive reputation.
Hello. I have a 2007 Ford Expedition with 72,000 miles. Over the past couple of months, we have been experiencing some sort of Shudder issue. Every once in a while, when we accelerate, the truck will shudder like the transmission is slipping or the engine is missing. It only happens once in a while. I took it to a transmission shop and of course they couldn't replicate the issue after two test drives. They put it up on the rack and said everything looked fine and that there weren't any leaks and the transmission fluid was full. They were stumped and didn't know what to do since they couldn't replicate the problem. Has anyone had this problem? If so, what was the issue? Thanks for your help!
Old 03-03-2013, 07:41 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
It sounds like a coil is going out. Pretty common.
Matt
Old 03-03-2013, 08:19 PM
Is that expensive to fix? Thanks for your help!
Old 03-03-2013, 08:47 PM
RI-Matt's Avatar
Should be under $100 and less than 20 mins to replace. The hard part is figuring out which 1 of the 8 is the problem. A mechanic with a good scanner should be able to tell which one is at fault.
Matt
Old 07-28-2014, 08:06 AM
dpobasil dpobasil is offline
dpobasil is starting off with a positive reputation.
shutter issue
having the same problem you described, did you find it was a coil issue, or a torque converter going out?
Dan
Old 07-29-2014, 01:02 PM
07EXPYEL 07EXPYEL is offline
07EXPYEL is starting off with a positive reputation.
Search on spark plugs causing the issue. You'll also want to change your spark plugs soon, better to do than wait to 100K miles when they're really stuck and might break. I did mine recently and it drives better, I got the updated factory plugs off eBay for a great price.
2008 Expedition Limited Shuddering DreaminGeek 2007 - 2014 Expedition & Navigator 12 08-17-2016 02:23 PM
2007 Edge Shudders between 40-50mph emville Crossovers 3 02-16-2016 09:56 PM
Fuel smell and shuddering when start on incline Joshing_Machine 1987 - 1996 F150 & Larger F-Series Trucks 8 11-19-2013 02:12 PM
1993 F-150 Shudder WuTang 1987 - 1996 F150 & Larger F-Series Trucks 3 01-31-2012 12:13 PM
ford shudder (weird) fast97gt 1997 - 2003 F150 7 11-29-2011 09:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
