upfitter high idle stopped working
been using the upfitter switched high idle mod for the last two months been working great and today it did not work. what are some things to check. did i understand that if there is a fault in the brake lights that it would not work, such as a burnt out light? what else should i check? ive never fully kicked the ebrake on, just enough to set the light which has always worked in the past. on our f550 rollback sometimes it takes awhile for it to kick in, i think because the computer has to make sure everything is where it wants it within specs?
SixGunCaliforniaKid
10-01-2011 01:48 PM
