upfitter high idle stopped working - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 03-03-2013, 12:28 PM
GHeTTo JOe's Avatar
GHeTTo JOe GHeTTo JOe is offline
GHeTTo JOe is starting off with a positive reputation.
been using the upfitter switched high idle mod for the last two months been working great and today it did not work. what are some things to check. did i understand that if there is a fault in the brake lights that it would not work, such as a burnt out light? what else should i check? ive never fully kicked the ebrake on, just enough to set the light which has always worked in the past. on our f550 rollback sometimes it takes awhile for it to kick in, i think because the computer has to make sure everything is where it wants it within specs?
Old 03-03-2013, 04:27 PM
GHeTTo JOe's Avatar
Found the FIX!
well i didnt but my Girlfriend did..... kept flipping the number 1 switch with no results and she says, i thought you used number 4........ guess what happend when i flipped number 4.... yup im an idiot. the f550 at work uses number 1 for pto ......
Old 03-03-2013, 09:25 PM
golfmedik's Avatar
golfmedik golfmedik is online now
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
Quote:
Priceless!
2 days research-can't figure it out sgrol 6.7L Power Stroke Diesel 6 11-02-2014 07:37 PM
08 Upfitter Switches-NOT WORKING-Help.. 1FastGambler 1999 to 2016 Super Duty 5 02-24-2014 12:20 AM
Power Door Lock Conundrum mattop 1999 to 2016 Super Duty 9 02-18-2014 12:55 PM
High Idle Mod with No Upfitters Brandon D 6.4L Power Stroke Diesel 6 01-10-2010 11:13 PM
A little wiring surprise Beach_Bob 1999 to 2016 Super Duty 1 08-01-2009 01:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
