2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Chrome wheel advice and help.
Old 03-02-2013, 08:44 PM
expoman55's Avatar
expoman55
expoman55 is offline
Hey guys my 10 limited came with those BEAUTIFUL Chrome CLAD ( ha plastic over steel ). I am considereing putting on a set of chrome custom wheels or purchasing a set of OEM alloy take off wheels. I live in upstate NY where they do use Salt on the highway. I am really only wanting to have one set of wheels and tires. Any one have any experience with chrome( my case Carroll Shely) chrome alloy wheels in a winter environment? I keep my vehicle pretty clean even in the heart of winter but it is an automatic wash vs hand wash.
Old 03-04-2013, 10:16 AM
markinnaples's Avatar
markinnaples
markinnaples is offline
I have an '08 Nav with the 20" factory wheels and they are just not very good quality. The truck came from Calif, then TX, and now in FL and it doesn't appear to have spent much time in snowy areas as far as I can tell, however, the chrome is pitting and peeling on the inner sections of the spokes. From 10 or 15 feet, you can't see it, but the chrome is definitely coming off. For this reason, I'd steer clear of the factory wheels as I'd hope a good quality aftermarket wheel would better quality chrome, but I guess you never know.
Old 03-04-2013, 08:33 PM
eddiemoney's Avatar
eddiemoney
eddiemoney is offline
Chrome doesn't hold up in salt, period end of discussion. 2 years max without nasty pitting.
You can get quite a bit more lasting with a clear-coated polished aluminum or machined aluminum in general..
Old 01-27-2014, 12:21 PM
oemwheelguy's Avatar
oemwheelguy
oemwheelguy is offline
I was doing some market research on what kind of wheels people like and stumbled across these comments. I figured since I used to work for one of the companies that made chrome-clad wheels I’d offer some facts that may be helpful. First of all you stated that the wheels were plastic over steel. However, they are the same high quality chrome used in grilles with a full layer of copper, nickel and chrome (Cu-Ni-Cr). There is no such thing as plastic chrome although there are some companies that make chrome thinner than others. Secondly, the salt performance of these wheels is similar to grilles since they use the same engineered composite material and Cu-Ni-Cr plating process.
Old 01-28-2014, 12:56 PM
berry1234's Avatar
berry1234
berry1234 is offline
Chrome plated plastic cap that snaps on to a steel wheel. The chromed over plastic just doesn't pop like a good chromed steel wheel or part.
Old 01-29-2014, 10:36 AM
eddiemoney's Avatar
eddiemoney
Ditto on the feeling!
Heyag33
2004 - 2008 F150
13
03-12-2022 09:18 AM
coldfront
2015 - 2020 F150
12-23-2016 02:02 PM
kalsc
07-03-2011 10:12 AM
markt1993
6.4L Power Stroke Diesel
03-06-2010 10:34 AM
climbhightree
Appearance & Dress-Up
03-04-2005 03:51 AM
Quick Reply: Chrome wheel advice and help.
