One project over and not the shifter falls apart.... - Ford Truck Enthusiasts Forums
S. California Chapter Join Chapter, Leader: wpnaes
Old 03-02-2013, 03:02 PM
boondocksnt's Avatar
boondocksnt boondocksnt is offline
boondocksnt is gaining momentum as a positive member of FTE.
So I finished replacing 85% of the cooling system, new radiator, pump, thermostat, thermostat housing, hoses, caps, etc etc. Then on the way home today the linkage assembly feel apart and I had to get towed.......
Does anyone know anything about there?
Its a rebuilt tranny, was 3 on the tree now 3 on the floor. the tow guy said just a bolt was missing but i head a LOT more metal clanking down the freeway then just a bolt. I never got to look at it so I have no idea what's missing. Am I going to have to pull the tranny to fix this?
Any ideas? Im sure pictures would help, let me know if I should take some.
Thanks,
Chris
Old 03-02-2013, 09:08 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
You should not have to pull the trans to fix a shifter.
In some cases, like my old Hurst 3 and 4 speed shifters, the shifter has a hole in the works so you can put a 1/4" drill bit through the works, aligning the stick and the rods to the neutral position.
You then put the trans in neutral and adjust the rods to the arms on the trans.
It really depends on what you lost as to how big a pita this will be.
Also, chock your wheels before you climb under this thing and put it in neutral.....
Old 03-03-2013, 10:33 AM
Thanks for the response 85, I am going to check it out next weekend. I may just go with a new shifter kit, I was reading about the Hurst kit. I just have to figure out which one I need.
kicking around 302 fi to carb. TenPlugs Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 04-15-2007 05:26 PM
dana 44 IFS diff cover? camccardell 1987 - 1996 F150 & Larger F-Series Trucks 4 03-11-2005 02:54 AM
Missing thermostat part 9explorer8 Explorer, Sport Trac, Mountaineer & Aviator 4 09-27-2004 03:46 PM
77 F100 Custom Shortbox Racerdave 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-21-2002 08:17 PM
Flex coupling for steering brewers78handdown 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-03-2002 11:00 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
