Needing OE Crossmembers: 58 F100 223
Old 03-02-2013, 12:53 PM
bwickham's Avatar
bwickham
bwickham is offline
Howdy all,
I'm new to this forum and have grand ideas of restoring a 58 F100 223/4 speed that I acquired a few months ago (it didn't come with engine or tranny but recently picked up a 223 w/4 speed). My objective is to restore it back to "close to original" but after getting the cab & bed off the frame I found the first three crossmembers were either missing or really hacked up (I assume the PO had a V8 of some sort)... live & learn.
Anyway, if anyone happens to have any or all of the first three crossmembers or know where to look (ebay, etc) I'd very much appreciate hearing from you.
Thanks in advance,
Bill
Old 03-02-2013, 04:00 PM
spurredon's Avatar
spurredon
spurredon is offline
Welcome to FTE. If you could post a pic of your frame it may bring you more results.
Old 03-02-2013, 05:15 PM
bwickham's Avatar
bwickham
bwickham is offline
Follow-up pics
Thanks for the welcome!
If I got these in the right order, you can see where the midsection of the first crossmember has had the midsection cut & folded back. The second may be okay but the welds on top didn't look too professional so I'm not sure if it's OE or not (what do you guys think?). The third is where it should be... you can see the remains of the it where it was cut off the frame.
I obviously need the third but can I make do with the first two or do they need replaced?
Thanks,
Bill
Old 03-02-2013, 07:46 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Here is a link to similar question from a few years back where ND listed the part numbers for frame rails and the some cross members. (see post #17) A google search for those numbers turned up nothing. I would say your best bet would be a donor frame/truck. Although Bill may show up with newer and better info for you.
https://www.ford-trucks.com/forums/5...7-60-f100.html
Good luck in your quest!
Old 03-02-2013, 08:43 PM
spurredon's Avatar
spurredon
I would agree with getting a donor frame. That certainly is a project. It could be repaired but you might wish you just swapped it out before you were thru! If you haven't already got one, a shop manual and master parts catalog will save you a lot of time and head scratching!
Old 03-03-2013, 05:04 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by theodore/teddy
Here is a link to similar question from a few years back where ND listed the part numbers for the frame and all the cross members (see post #17). A google search for those numbers turned up nothing. I would say your best bet would be a donor frame/truck. Although Bill may show up with newer and better info for you.
Just ran all six of these part numbers on three parts locator sites: No Ford Dealer or obsolete parts vendor has any.
Old 03-03-2013, 09:13 AM
theodore/teddy
Refyred
Thanks Bill for all that you do!
Old 03-03-2013, 12:07 PM
bwickham's Avatar
bwickham
bwickham is offline
Thanks for your help
Thanks all for your comments. Via one of the links you provided (auto-part.com) I found a local salvage yard that has a 1960 frame! I'll give them a call and see what they've got.
Thanks again,
Bill
Old 03-04-2013, 04:47 AM
3414's Avatar
3414
3414 is offline
On the first crossmember the motor mounts are intact. Depending on your welding skill, you could unfold it and weld it back together. The second does not belong there, so it can go. The third is necessary. Keep an eye on Ebay, local classifieds, and local salvage yards.
Good luck in the search.
Old 03-04-2013, 03:57 PM
bwickham's Avatar
bwickham
bwickham is offline
That's what I was needing to know! Thank you!!
red04gli
02-10-2015 02:14 AM
sofob0909
06-13-2013 10:19 PM
JaxBob
09-04-2008 08:11 PM
JERRY WESCOTT
10-26-2006 06:59 AM
Meilichios
Offroad & 4x4
12-11-2004 12:11 AM
Quick Reply: Needing OE Crossmembers: 58 F100 223
