Needing OE Crossmembers: 58 F100 223 - Ford Truck Enthusiasts Forums
Old 03-02-2013, 12:53 PM
bwickham bwickham is offline
bwickham is starting off with a positive reputation.
Howdy all,
I'm new to this forum and have grand ideas of restoring a 58 F100 223/4 speed that I acquired a few months ago (it didn't come with engine or tranny but recently picked up a 223 w/4 speed). My objective is to restore it back to "close to original" but after getting the cab & bed off the frame I found the first three crossmembers were either missing or really hacked up (I assume the PO had a V8 of some sort)... live & learn.
Anyway, if anyone happens to have any or all of the first three crossmembers or know where to look (ebay, etc) I'd very much appreciate hearing from you.
Thanks in advance,
Bill
Old 03-02-2013, 04:00 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Welcome to FTE. If you could post a pic of your frame it may bring you more results.
Old 03-02-2013, 05:15 PM
Follow-up pics
Thanks for the welcome!
If I got these in the right order, you can see where the midsection of the first crossmember has had the midsection cut & folded back. The second may be okay but the welds on top didn't look too professional so I'm not sure if it's OE or not (what do you guys think?). The third is where it should be... you can see the remains of the it where it was cut off the frame.
I obviously need the third but can I make do with the first two or do they need replaced?
Thanks,
Bill
Old 03-02-2013, 07:46 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
Here is a link to similar question from a few years back where ND listed the part numbers for frame rails and the some cross members. (see post #17) A google search for those numbers turned up nothing. I would say your best bet would be a donor frame/truck. Although Bill may show up with newer and better info for you.
http://www.ford-trucks.com/forums/56...7-60-f100.html
Good luck in your quest!
Old 03-02-2013, 08:43 PM
spurredon's Avatar
I would agree with getting a donor frame. That certainly is a project. It could be repaired but you might wish you just swapped it out before you were thru! If you haven't already got one, a shop manual and master parts catalog will save you a lot of time and head scratching!
Old 03-03-2013, 05:04 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by theodore/teddy View Post
Here is a link to similar question from a few years back where ND listed the part numbers for the frame and all the cross members (see post #17). A google search for those numbers turned up nothing. I would say your best bet would be a donor frame/truck. Although Bill may show up with newer and better info for you.
Just ran all six of these part numbers on three parts locator sites: No Ford Dealer or obsolete parts vendor has any.
Old 03-03-2013, 09:13 AM
Refyred
Thanks Bill for all that you do!
Old 03-03-2013, 12:07 PM
Thanks for your help
Thanks all for your comments. Via one of the links you provided (auto-part.com) I found a local salvage yard that has a 1960 frame! I'll give them a call and see what they've got.
Thanks again,
Bill
Old 03-04-2013, 04:47 AM
3414 3414 is offline
3414 is gaining momentum as a positive member of FTE.
On the first crossmember the motor mounts are intact. Depending on your welding skill, you could unfold it and weld it back together. The second does not belong there, so it can go. The third is necessary. Keep an eye on Ebay, local classifieds, and local salvage yards.
Good luck in the search.
Old 03-04-2013, 03:57 PM
That's what I was needing to know! Thank you!!
58 F100 T-19 and 351W Studebakerhawk 1957 - 1960 F100 & Larger F-Series Trucks 10 08-28-2015 09:06 AM
223 with C4 OldFords Ford Inline Six, 200, 250, 4.9L / 300 6 04-29-2015 07:09 PM
1956 F100 3 Speed Overdrive Transmission Conversion dadz34 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 05-06-2014 06:37 PM
In need of a crossmember or two from 53-56. Huntfamily53 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 10-30-2010 03:23 AM
Pics of F&R engine mounts 223-6 59'er F100 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-10-2004 05:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
