1960 F100 with no key. Looking for the code. - Ford Truck Enthusiasts Forums
Old 03-01-2013, 11:06 PM
uknunn's Avatar
uknunn uknunn is offline
uknunn is starting off with a positive reputation.
I'm about to buy a 1960 F100 Flareside Pickup. The owner passed away and it's coming with title but they can't find the key. Any idea where the key code is? Possibly in the door lock somewhere, and how easy is it to take apart to find the code? I'm off to Pomona Swap Meet on sunday hoping to get the key made.
Thanks.
Old 03-01-2013, 11:18 PM
willowbilly3 willowbilly3 is offline
willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.
No way of knowing if the ignition switch is original but you should be able to pop a door lock and take it to a locksmith to get a key made.
Old 03-02-2013, 06:44 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Welcome to FTE
When new, these trucks came with two sets of keys, round discs with the key codes on them were on the key rings. Ignition/door lock cylinders key code begins with FA followed by 5 numbers.
Unless one/both of these discs are still with the truck, possibly inside the glovebox or ashtray, you'll have to have the locked 'picked' by a locksmith.
Why go to Pomona and walk 10 miles in the heat since any locksmith can do this?
The thing is, if you remove the left door door lock cylinder, how do you know if it's original to the truck?
Remove the right door lock cylinder (if so equipped), it isn't used anywhere near as often as the left, so it's probably the original.
Open the door, there will be a clip visable that retains the lock cylinder. Pull clip out, remove cylinder.
Old 03-02-2013, 07:55 AM
Damifiknow's Avatar
Damifiknow Damifiknow is online now
Damifiknow is starting off with a positive reputation.
Should any locksmith be able to read the codes and make keys?
Old 03-02-2013, 09:18 AM
There's a code book for single side "5 cut" keys, another for double side "10 cut" keys.
Most locksmiths will have the double sided code book, because these keys were introduced in the mid 1960's (some passenger cars initially) and were used thru the 1990's.
Single sided keys were fazed out by the late 1970's.
5 cut keys: The tumblers (cuts) are known as 1 thru 5, as that's their depth, with 1 being the shallowest, 5 being the deepest. If you pop the cover off the cylinder, there's 5 tumblers inside.
Locksmiths, some Ford parts guys can 'eyeball' the depth of the tumblers, cut a new key by using a hand cutter.
Old 03-02-2013, 05:20 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Just hot wire it to get it home. Then order a set from, say, LMC truck. Get a switch while yer at it. This truck is one year younger than I am! Who knows how many people have a key for it or what kind of shape the locks are in. Under a hunnert bucks buys a buncha piece of mind
Old 03-04-2013, 09:40 AM
Quote:
Go right on ahead, buy the parts from LMC. Then they'll use your money to buy the parts elsewhere, marking up the price, then charging you the extra shipping charges.
LMC reproduces no parts of their own and has next to no parts that are listed in their catalog. LMC is a "middle-man" operation, uses the J. Paul Getty method of making money-see above.
BAAA-8122050-S .. Door & Ignition Lock Set w/2 Keys / This is a Dennis Carpenter "made-up" Ford part number: 1953/60 F100/1100: 50 bucks = 800-476-9653.
B2A-7022050-B (replaced B2A-7022050-A) .. Door & Ignition Lock Set w/2 "keyed alike" Keys / These are the "original" Ford part numbers / Obsolete
Applications: 1953/60 F100/1100 & 1952/58 Ford Passenger Cars except 1957/58 Skyliner ('Flip Top") & Sedan Delivery.
NOS PARTS LTD in Waxahachie TX has 5 = 972-937-2201.
VINTAGE PARTS INC. in Beaver Dam WI has 71 = 877-846-8243.
Old 03-04-2013, 11:03 AM
vntgtrk's Avatar
NumberDummy not only saves the day he saves us money.
Old 01-17-2014, 02:41 AM
Vsanzbajo's Avatar
Vsanzbajo Vsanzbajo is offline
Vsanzbajo is starting off with a positive reputation.
Were the ignition and the door lock, the same key?
Old 01-17-2014, 03:32 AM
uknunn's Avatar
I'm gonna buy new passenger door lock and ignition. Only $50. Still haven't done it but I will soon!!! No drivers lock as never came with one!
Old 01-17-2014, 10:35 AM
millertme millertme is offline
millertme is starting off with a positive reputation.
My truck didn't come with keys. Lock smith's wanted 100 bucks to rekey the truck whether the cylinders were pulled or in place. Ended up buying a new ignition switch and all 3 locks @ Vintage Ford for <80 bucks. Great choice!
Old 01-17-2014, 02:11 PM
Quote:
Yes, and "Vintage Ford" referred to in post 11 is Sacramento Vintage Ford.
Old 01-17-2014, 05:40 PM
Damifiknow's Avatar
He is an awesome man if you ask me.
Old 01-18-2014, 10:45 AM
I live in Sacramento so for me it's just "Vintage Ford" :P Thanks for the fill-in.
Old 01-18-2014, 12:08 PM
vntgtrk's Avatar
Quote:
As long as you don't live in Rancho Cambodia or Syphilis Heights it's all good
New '60 F 100 dcmania 1957 - 1960 F100 & Larger F-Series Trucks 16 02-11-2017 12:01 PM
Radio Caveman2851 1957 - 1960 F100 & Larger F-Series Trucks 2 02-05-2017 10:59 AM
1960 F100 4x4 front axle closed knuckle Caveman2851 Ford Truck Parts for Sale 5 10-18-2016 12:39 PM
1963 to 1960 f100 frame swap? ctorres 1957 - 1960 F100 & Larger F-Series Trucks 0 02-18-2016 05:42 PM
Power/Tilt steering for a 1960 F100? 77Chief 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 02-24-2005 10:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
